Disco II Stange clunk in steering - Advice needed...
Old May 16, 2010 | 07:12 PM
bmw zhp's Avatar
i was hearing a clunking sound in the front end check every thing out under there and sure enought found the problem.turned out to be the bushings on the shocks
was all rotten there was like a 1 " inch of play.
Old May 16, 2010 | 09:03 PM
overfences's Avatar
I've got an 02 with 103k miles on it and i've had the feedback since i got it a few months ago. Mine is a "skip"/feedback when I turn left and it hits around 45 degrees. It's nice to hear i'm not alone. I'm going to plan on clearing out the old ps fluid. I'll let you know about that.
Old May 17, 2010 | 02:22 AM
Spencerfitch's Avatar
I guess mines the worse since it does it with turning stopping or accelerating.
I'll check my bushings.
Old May 18, 2010 | 01:00 PM
TripleThreat's Avatar
Throwing it on the lift tomorrow to check sway arm bushing and shock bushings...
Will report back results...
Old May 31, 2010 | 02:09 PM
Still no clue... Thinking now that it must be somewhere in the ACE package...
Old May 31, 2010 | 05:11 PM
njb8199's Avatar
Check your motor and transmission mounts.
Old May 17, 2011 | 07:37 PM
Finally found the issue here...
Sway Arm Bushings on the ace package are bad. Here's how I found it...
You have to jack up the front of the vehicle and take the load off the suspension. Once you take the load off the suspension, you can grab the sway bar and it will move around in the bushings under the two clamps.
I ordered replacement bushings, but they come un-split, since it would be nearly impossible to install them without splitting them, I'm pretty sure I'm going to have to split them. In fact, the tech support guy at Atlantic British was surprised that they didn't come split.
I've heard that the spilt should face the back of the vehicle on the right side and should face the front of the vehicle on the left side.
I'm certain this is my problem, and with the suspension loaded it is impossible to feel the play.
Has anyone replaced these bushings? Any advice? Which way did you align the splits?
Old May 21, 2011 | 10:51 PM
The image on the RAVE CD shows the bushings as split, with the splits both facing the front of the vehicle. Installed them on Friday and it eliminated the clunck completely. It also made a noticeable difference in handling crispness.
Old Mar 30, 2012 | 04:40 PM
txjag1023's Avatar
I cant let this thread die. I want this fixed!
I went under the truck with a rubber hammer and beat around, found nothing in the stearing, other than the front springs resonating when being hit, but thats not the sound I hear when it knocks anyway..
We have to figure this out!!
I tightened the shock tower nuts, well one of them, it seemed pretty easy to tighten, I mean it wasn't easy but it didnt feel tight either, I was afraid I might strip the bolts so I stopped
Did anyone ever figure this out, mine is doing the smae thing, I have repalced, the track rod ends, the ball joints, the brakes, the steering joint, the steering gear even, all of which needed to be replaced, but ti has a clunk and a tiny bit of freeplay which im thinking is a steering gear adjustment but the clunk is a bit annoying
Old Mar 30, 2012 | 05:41 PM
jfall's Avatar
So, I noticed that the Discovery II has CV joints in it now like a car does.
Could the CV joints be sticking or going bad?
If you go really slow - like 1 MPH and try this - is the clunk the same as if you are going
5 to 10 MPH?
Also -
I would check the steering box bolts. Make sure they are up to torque specs.
If the steering box is loose, it will clunk.
check the large nut which holds the Pittman arm on too.
