Disconecting the ABS on a 94 Disco
I have a 94 disco and i think my abs sensors are not working... because intermittently when I press the breaks i gets some resistance and hear a zzz noise.. it will be like 1500 dollars to get the sensors fixed and I dont have that money. I was suggested to disconect the abs motor.. I was wondering if anyone has tried this and if anyone has any comments.
cheers
m
cheers
m
Are you sure it is the sensors? Did you do a check of the fault codes? I can send you a test procedure that I believe works on the 94 Disco, as I think you have a Wabco ABS similar to my 95. I would also do the usual stuff-bleed the brake system, check fluid level...
I am have the same problem with 95 Disco Anti lock light stays on. Today I removed both front wheels pull out sensors and cleaned and put thme back in. Still have Anti lock light on. Does anyone have a test procedure for the sensors. The brakes seem to work fine. How do you check fault codes?
Well the flash codes if they work (ha ha) dont. pull the sensors and dont break the phillips screw from hell holding them on (P B blaster overnight) then pull out each one and see if deformed or demaged. Then as said earlier take an ohm meter test the 2 pins then test each one (should be araound 10 ohms of each other) then to the shield tube of either pin each one (stainless piece around the base around an 2 inches long, any continuity above 40 ohms is a problem (oil or water) compare them to each other . One last note when replacing them clean the s--t out of the signal wheel inside the hub (brake clean)
I finally figuired (through other posting) how read out and get the the code. I had changed the Brake Light Switch last week because i couldn't get out of PARK. The yesterday I found out that my BRAKE LIGHTS are always on. So I piut the OLD switch back in the the brake lights and shift lever work fine. The ANTI LOCK light is still on. I did the Blue Test Plu. and got 2-6 code which says.
Brake Light Switch failed or fault in wiring. But all works fine. Has to be a way to reset that ANTI LOCK light
