disconnecting driveshaft
The front driveshaft is an easy bolt on swap. The rear (from what I can tell) requires me to replace the pinion flange. There is a tech page on Discoweb about this but it doesn't list what torque the pinion bolt needs to be wrenched to. I don't plan on having more than 1 to 2 inches of lift, so the rear roto-nonsense may last. I would prefer to swap it out and forget about it.
Cheers,
Pete
Cheers,
Pete
You'll need more than just the drive shaft. There's a spacer and flange you'll need also. AB has the kit but it's pricey. Your best bet would be to call a parts guy and get what you need that way.
http://www.roverparts.com/Parts/9300.cfm
That's what I'm looking for. Thanks! Now all I need to do is adjust my budget. The website shows it listed for Disco I models. Does it fit my 2000 Disco II? If not I'll probably just stick with a new Rotoflex since I only have a 1 inch lift and very little power going through to axles (182hp at sea level, who knows at 7000 feet or above).
Cheers,
Pete
Cheers,
Pete
2000, disconnect, disconnecting, discovery, drive, driven, driveshaft, front, land, landrover, range, rear, rover, shaft, treadwright
