Discovery "do it yourself" lifting
on
You don't use spacers as your primary lift. No since taking your Disco tired coils and throwing spacers under them all you get is a top heavy vehicle that will sway badily off road and on turns.
The only true lift is to replace your shocks and coils.
Mike
Mike
Mike is right, the best way is to replace the coils and also get longer shocks. The reason to lift a vehicle is to increase the off-road performance, doing it cheaply will just cause other problems. My recomendation is to save your money and do it right the first time, this will include coils, shocks, extended brake lines,longer sway bar links, tires, alignment and so forth. Also dont forget many parts will wear out faster when used off-road or lifted before they wouldnormally. Just my .02.
mln01
06-17-2015 09:44 AM
hazletbassist89
04-12-2009 01:26 PM
