Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old Oct 7, 2018 | 08:28 PM
  #111
ACEngineer's Avatar
Originally Posted by D24.6
Thanks for the reply,
I can't find find any 4.8 or 5.3 LS engines here in Australia. However, 5.7 LS1 Gen 3 are very common (and cheap) and I was worried about the ZF handling the power.
After reading your reply though, I think it's worth a shot with the ZF. Plus I want to keep the cost down as much as possible.
Looking forward to further updates and finding out when your kit is available.
The engine in the prototype is making about 335 ft-lbs. An early LS1 is rated at between 350 and 365 ft-lbs, so it's really not that much more torque. We are putting a bigger cam for the engine in my off-road rig, so that will probably be approaching (if not exceeding) same torque as a stock LS1.
Old Oct 10, 2018 | 11:39 AM
  #112
Kgman's Avatar
Default Bump for updates?
Any word on the website? Just bought a 2000 Disco 2 with a slipped sleeve and probably bad head gaskets and would really rather do the 4.8 or 5.3 than rebuild the 4.0. Would want to do it soon too, like maybe over Christmas break
Old Oct 10, 2018 | 04:57 PM
  #113
Nosugar0carbs's Avatar
Every time someone posts on this thread it get me excited. Can’t wait for an update and a kit. At the moment, I am just going to turbo the loudes tacking rover of mine till it blows up. We need this kit published already
Old Oct 10, 2018 | 06:06 PM
  #114
ACEngineer's Avatar
The website is up: www.lsdiscovery.com. The products are not visible right now, but there are some more pictures on there, as well as an FAQ section.
Right now, we are aiming for early December for non-emission kits. This is subject to change, but if everything continues to go well, I think December is feasible. Emission-ready kits should follow up a few months afterwards. I appreciate everyone's patience up to this point. I just want to make sure what we send out is reliable. We're mostly waiting on electronics at this point. Most of the other parts have been fabricated.
We just acquired a new '99 Disco 2 which should serve as a general walkthrough and 'budget build' example. Probably going to go with the 4.8 and the stock 4HP22 transmission.
Runs good, but sounds a bit like a lawnmower with an external head gasket leak.
Old Oct 10, 2018 | 06:23 PM
  #115
Kgman's Avatar
I can’t wait to see the 4.8 build
Old Oct 10, 2018 | 06:36 PM
  #116
Congratulations on the site. Can’t wait to see what’s next.
Old Oct 10, 2018 | 07:44 PM
  #117
dgi 07's Avatar
This. I know alot of guys want 5.3 power, but there are a few of us that want that 4.8.
Old Oct 10, 2018 | 08:44 PM
  #118
ACEngineer's Avatar
So my plan for the 4.8 budget build is to do basically everything myself, which should significantly save on cost.
Since we’re on a budget, we’re looking for the most complete engine we can find. Junkyards tend to take most of the accessories off the engines and sell those separately. They also charge for the ECU separately and cut the wiring harnesses. If you can find a junkyard that will give you a ‘drop-out package’, then perfect, but most in our area don’t do that. Therefore, our best options for finding an engine are Craigslist and Facebook Marketplace. Getting a whole engine complete with all accessories, starter, throttle body, intake, coils, ECU and wiring harness is best. There are deals to be found.
On Craigslist right now is a local listing for a 4.8 with all the accessories, the GM ECM, and wiring harness for $350. I'm probably going to go take a look at it this weekend and if it looks okay, buy it. The risk to this is I can't return it, but for the price, I'll do it.
Instead of buying a premade wiring harness, I'll modify a used GM LS engine harness. It is time consuming and tedious to modify, but it is not overly difficult. There's a lot of videos about it online -- I'll find some to post here. The premade harnesses are great and there are a number of companies that build them, but they can be the priciest part of a swap. Another budget option is to search Craigslist to see if any local people have harness modification services. There is a local guy here that will modify your GM harness for $300.
Once I've got the GM harness done, sending off the ECU to be flashed is no big deal and costs less than $100. After that, all you really need is our kit and a couple weekends to do the physical swap.
I'm looking forward to seeing how this goes. Should be a lot cheaper than buying a harness. The GM 4.8 has almost the exact power stats as the Rover 4.6 so it should be fairly easy what to expect power-wise. I also think the 4HP22 could handle the 4.8, since people swap the 4.6s in with the 4HP22 all the time. Should be a fun project.
Old Oct 13, 2018 | 02:00 PM
  #119
I was close to pulling the trigger on an engine gasket set with arp headstuds and new rockers. I think you saved me from continuing. Looking forwards to the sales products of the website
Old Oct 14, 2018 | 03:31 PM
  #120
alecsstefan's Avatar
3rd Gear
Will this conversion kit fit the european version of the D2 V8? Mine is a 2003 4.0 but not sure about the auto box if it's 4H22 or 4HP24. I'm very interested in swapping the 4.0 with an LS.
