Discovery 2 Suspension Popping/Clunking
Old 06-01-2022 | 07:05 AM
adalton's Avatar
Default Discovery 2 Suspension Popping/Clunking
Hi everyone,
At slow speeds and when rocking the truck back and forth the suspension seems to be making a clunking noise from the center of the truck. It only is noticeable at slower speeds. Any ideas on what it could be?
Thanks
Old 06-01-2022 | 08:06 AM
whowa004's Avatar
could be any number of things. Watts link, radius arm bushings, exhaust/exhaust hanger, sway bar....crawl under there and start pushing on stuff or have someone rock the vehicle while you're underneath.
SundayFunday (06-07-2022)
Old 06-01-2022 | 11:35 AM
ABC's Avatar
ABC
8th Gear
My discovery 2 makes the same or similar noises went under poking around couldn't figure it out needed a second person weirdly enough recently it stopped
Old 06-01-2022 | 11:51 AM
redwhitekat's Avatar
shock bearings time for a 2 inch lift
Old 06-01-2022 | 12:52 PM
acg's Avatar
acg
I had a similar issue when off-roading last summer. Turned out to be a hairline crack in one of the polymer bushings in the radius arm. The initial visual inspections of the underneath of the truck did not reveal anything as the crack was not very visible. Pieces of the bushing started delaminating and disintegrating further with continued offroading (4 days in the bush). Getting someone to rock the truck back and forth while someone else is underneath to check it out is advisable. I ended up using JB Steekstik to fill into the missing cavity until I was able to get back to civilization.
Old 06-02-2022 | 06:43 AM
adalton's Avatar
Had my friend rock the truck when I was under it. Sounds like its coming from around the fuel tank? Very confused.
Old 06-02-2022 | 04:12 PM
H Hill's Avatar
Either Watts link bushing or if you have ACE, your link from the sway bar end to the ACE link could be bad. Check both.
T-rex (06-04-2022)
Old 06-02-2022 | 04:14 PM
adalton's Avatar
I have an SE so I don’t have ACE but I’ll check watts link.
Old 06-03-2022 | 09:19 AM
frostythor's Avatar
it took me a few weeks to find what my problem was and that included a trip to my local garage who could not find anything wrong, they said it may be the shocker/damper, so I took it home jacked it up took off the shock/damper, tested it all good but I could not get it back on so I have to lower the axle more and that when I saw the ball joint on the drop link come out of the cup, but due to them being old when I went over a bump or round a corner it popped out the banged back in, so unbolt one end of your droplinks and test the ball joints are good, they are not expencive cheap and easy to replace
Old 06-04-2022 | 04:20 PM
Frank4's Avatar
A new Watts linkage solved this for me.
Quick Reply: Discovery 2 Suspension Popping/Clunking
