Discovery II Rear Light
RE: Discovery II Rear Light
Welcome tot he forum, I am sorry to say I can not help you fully as I don't own a disco myself, but it will have only one of either two ways of getting to the bulbs.
One is by screwing and removing the lens cover, the sceond would by checking inside to see if their is a quick release cover behind the light fitting.
Just for the record----there are several screws on the lens that need to be removed. Once the lens is out, there is a metal cover that also needs to have several screws removed. (It should be pretty apparent once you take the lens out.) You might want to get familiar with the procedure because, in my experience, the bulbs burn out regularly.
Regards
Regards
LADEROUTE
11-11-2014 10:59 AM
bcolins
06-22-2013 08:55 PM
Paul Grant
03-29-2012 06:02 PM
marlymarl
05-28-2011 10:34 PM
97LANDISCOVERY
08-19-2007 04:10 PM
