Discovery Radio Problem
Old Feb 16, 2014 | 07:19 AM
wastesandpines's Avatar
Default Discovery Radio Problem
I just purchased a 2004 Discovery S.
One of the small issues with the car is that the volume **** on the (factory original) radio does not function correctly. If I attempt to turn the volume up, it only goes as far as level 3 (very faint), and while doing so the numbers on the LCD display flash in a sort of crazy way.
When I adjust the volume with the steering wheel control, the volume goes up and down as normal. So the issue seems to just be with the **** on the radio.
Does anyone have any ideas about a possible solution? Is there a way to factory reset the radio unit, that might resolve the issue? Any insight would be great.
Thanks!
Old Feb 16, 2014 | 08:28 AM
Disco deuce's Avatar
You could replace your radio. Or if you just want the factory radio you can replace the potentiometer.
dogstarsix75
Apr 24, 2020 01:33 PM
lvshust
Aug 21, 2018 02:29 PM
moocowman
Aug 31, 2011 04:07 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
