Discovery2 - Need help with sudden battery drain
Old 02-21-2023, 10:24 PM
TejasRover's Avatar
6th Gear
Default Discovery2 - Need help with sudden battery drain
Hello all
This is my first post, up until now I have always been able to find my issue and fix it with the forum so well done creating a wealth of knowledge.
I have an ongoing issue with my 2001 Land Rover discovery2 where the battery will drain within a matter of 15 min when it was other wise working and charging as it should as far as I could tell with a Bluetooth battery monitor.
I have recently replaced the battery and had the alternator rebuilt which seemed to fix the charging issue I was having. (Voltage reg was bad) the only thing that is a common factor now for the voltage to drop is the use of the air conditioning system. After I have turned it on for anywhere from 15-45min the battery will drop from around 14 volts to ~11 volts. When I turn the ac on it will drop .3 or .4 volts and stay that way.
turning the AC off does not allow the car to recharge the battery but it is probably too low at that point
any ideas what could be causing this or are these not likely connected?
Old 02-21-2023, 10:55 PM
Richard Gallant's Avatar
Received 1,177 Likes on 814 Posts
That sounds like the alternator, when you fire up the the AC that adds extra drag on serpentine belt. All thing being equal you will see a bit of a drop, as the clutch kicks in and the internal blower fanis running. My Disco will drop form 13.6 to 13.3 -fan on high, it returns to 13.6 + as soon as the AC is turned off.
But it could be something else - including the battery.
Start simple:
Start your truck and check the voltage output at the alternator with a multimetter it should be out putting around14.0
Turn everything on except the AC,stereo, head lights on hi, hazards, heater on max fan, fog lights if you have them
Now you should be running around 13.4 to 13.6 possibly higher depending on battery state
Finally switch the A/C on you should still be above 13. volts I run at 13.3 in that state - on an old alternator
Old 02-22-2023, 08:46 AM
Showing results for parasitic draw test on car
Search instead for parasidic draw test on car
Search Results
Featured snippet from the web
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBwgHBgkIBwgKCgkLDRYPDQwMDRsUFRAWIB0iIiAdHx 8kKDQsJCYxJx8fLT0tMTU3Ojo6Iys/RD84QzQ5OjcBCgoKDQwNGg8PGjclHyU3Nzc3Nzc3Nzc3Nzc3Nz c3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3N//AABEIAKAA1gMBIgACEQEDEQH/xAAcAAABBAMBAAAAAAAAAAAAAAAGAwQFBwABAgj/xABBEAACAQMCBAQCBwcDAgYDAAABAgMABBEFIQYSMUETIlFhMn EHFEJSgZGhIzNiscHR4RUkcvDxFjRDorLSJYKS/8QAGgEAAwEBAQEAAAAAAAAAAAAAAAECAwQFBv/EACURAAICAgICAgEFAAAAAAAAAAABAhEDIQQxBRJBUSITFCNxk f/aAAwDAQACEQMRAD8ArvifhW602R3tczWrE4IO6exH9a54sjRWt 3jChljAYj5CpXUeImYEIdutC17cTXsp5gST19hQ2TRL8KahZWb PNdFiy9FNTOpcYl1MdipA7GgDBUn22FSOmsGjZTgEUNgOb28ur t83ErHvUe25p3csMbGmRYUBRo+tb7VyGGMGk5JCRyhjg9qVhR3 ISh5WBB960gd3VUUszHYetaVZLiULux9WOfzpxJMLVDDb7uw88 2OvsvoKLBHcmLGPljKvOdmkB2T2FMgHVg2ObfcetdRZj3dW5G+ Lv+NTdtZiVTFCVYspLyHYAfPsPenQNm9MiWUIbcF3bv6e1Ialq MVsJLWyZS5HLLOP/ivt796b3d7BbwvaaYzCJ/3s3Qyn29F/nUST6UxmBiCCOtKc2d8BflW4OVcsRkntWFWdsgbUgEzv+FdKrc mQp6/FjajLhX6PNS123S8eSK3tiwxzbsy9+nT8asHj/wD8P8N8DNowtIZLgx8lsJI/OWJHM4OO3Wix0UfGGUl8432xRtwfxTLZXCRSP3wM96Bw5wB2ra OysCDuOlL5Jdnoxtas0sYrqY8pcZ5QaCeJON4XRoIlDKcgr1oA fVr6eBYZJ3Ea9N63Jpl0bKS+IRbVWCtI0g6n2/EfnVWBZ30ScbpcBOHtRcI6AixkY/EoP7s+4HT2HtVo3UCXVvJBLsjrjPv615JWZo51kidlZDlWU4Kn sRXoD6MeOU4js1sNQdV1aFcHt46/eHv6j8allBzpMsthElvcMZIhsr9x7U6eNjM5Duxz8TenpTG5J8 FgMk9gO9PfrcbWP1iLzhRuvcev5UgPPX0yaLdWHFtxqc6YtL8q 8Ui7jIUAqfQ7Z/Gsq+LqC01OER38EUqq3MEkTmHoCPwrKdAeZo7BIzzXMuSfsJvj 8elc3BAj8ONAoP2V7/M9TU9pfDmp6kFdgsEIP7yTbb5VNmLh3hteeYrdXQ7npn5VdEfA H23DzyWsl5eHwIwuULg+aoRWETvybLRLxNxddaqjRQxCO3Gw9a EiT3Oc1LAVeUv32pMtXNapWM6zXUETTycifiT2FahjM3oqjcsa 6mkBHJF+79+/vT/sR3LIIkaCLKqfic9XP9q4g2cJLsudie1HX0WWYk1d7nULSKS2e 0kjQzgYfpvv8utD2r2g069ezvrZoomfKsNyN/Tv8v50lNN0i/R1Z1DaLKrKHVYguZJW6Af2qPvr9FtvqWn86WucszHzSn39vaut QuZJYhb2yFbOLdQDksfvN7/yqPSCWTG2BTFQixzUtonD95q74iAjjHWVxt/mtWlmqSJtzsxwM9qs/RbVrTSlUAF8ZG3emkForbVdDk0uXwpmDHswGxo44L4Y4cubOK+ 1Bb/x4ELSqHHhs22CFxk49K5k0q51A8+pFvK3lVd8e1Ia54VtYRTQy 2/+1lDrEZMHbqPmfSlJa0C7LIsxHDZahLYrJavCCVb7ygZUn5/Kq++kuxF3pUGrXly63CJyxoSGEuTkn2riHj261DTLm0sIYra7l wviO2FRO+NqaaPwXq/EJYtIfCOWadkKoufTO57+grnxwnezaUo0V8Ry9/zrpRmra1Phjh3h+3gtik19NKG5pwuASBnAP+KgdX4KX6kdS0QN NGU5zC5+H3BGx+VdNGIJ25imSOOKB5bjJPJny/j7flitXjloPBSZ7h+fnkdD+zBxjA7Htv7VqDx/qvKT4UOTzHGC/t70jeXvjxrbxZWBOiDYH3PrSChFomXdtql7a0u9KWLUIpntr2A CeIgjcD0/CoQscbE/KlWmmmADOzADABPb0pAem+Dtej4k4dtdRXCyMOWZF+zIOo/69an7W1fJuLXKv9odmHvVU/QcZYLTVbOT91zJMoz3IKn+Qq5tIGLNT60hiFvHbyZPKY2+0mcY NZTu5tFmPMNm74rKYHlrV+NNR1AeFC3gx+xxUCA9wxeSRmyfMS TTSNhzDn+HvUzcQxQ2akyoZ35SkcZyEXuWPypkjNiGZYocZBwB 603niBy8YPl+Ieh/tStmipdrMxz4bcwA2zjvXBuUWWSSNcsSRv0xQwGtdJGzDmPwdz WKM7kYp7pthf6lMEtIWZR1OMIB7mp0tsuEJTdR2MpJC2Ag5UXY AVyqFzgVYGmcBWTJi/u5Oc9otlH4mo/iDhI6TIZYvEe1G/8AEp9z6e9SssXpHVPg5oR9mh7w1q1tI1vBJM0LRpylUkEY5R6Z 2/Kn3EXF9hJbtDYWkM0oXwhNMnMVHqCRufegu00C91F/9jHJcS7YihQu5Odth0+dS2pcN6jw5aQTcQWkngTN5ZYZA4jP3G x0ahQSdo5pTk40DjRXBlM0bMXJzzKcHNKw3XhzKt/EwQndguG/zUpY3WjRT5edymB8URoqzw/rNqIGmtnB+EBwHX+taGZG8P6RDeMlxFIHhDeXbf8AGjhVCxcoH QYqtriy1PhG9W7sZGlsnO7HdWHo3p86N9G1u31q1WW0dRKow8W fMv8A1600x0Olk5GygCxYznuf81B3/Bh1m/Eum22WY+YdAfUn3oh05rWeZo2kEjwvyMmcEHrj8ulOv/Ejm8TT7ewksrcsyEqCfMOmWHXIpgMNP4M0fhe1kvLlV1G+iBfw Tgrt2z2NSdjr41hpPDt2tUjCgxcnJnbPw/1NLNIqLlu/bNRGravbWC88koUn4Qm7ufYDc0ICadVOMqGdTttuP7UK8T3sl0 INI0/U5RL4uJoLVdkQnfLDptXVjZ69xTctFYxSWlpnlcg4Y+zP0X/iMtVlcIcDaboMauUE1yN+Zh5VJ64B6n3OTQ2B594o4V1iwP1iR JJrblyMDBQe4oVGebNey9U0u21KExXSecjCso3UVSnH30WvbvJ c6YgRjk4UYR//AKmpAqIrgZ7d6UgKo6c+y561IW9o8fi293E8cybMki4Ipu1mX5 iBg52pAWz9D93BdXmox27ElYE5tv4quvTNrYL6VRH0EqIb/WEcDmaGNgfYE5/mKvbS/wDy/wCNAx4KysrKYHiLNL2s5iDR/Zamorsb0CY6luAuAnx/e9Pl71qytJ7yZYoImkkPRVGaRjUMwB6kgVaui2VvptnHHaqMkA u/dqyy5FBHdwuH+4k96RCaRwWqYl1WQN6QIenzNFUcUVtEsUCLHG PsqMClQQVLYGa4OMjfr2rhnkcj6PBxseFVFCiAMSG3J6dh+NP7 VTcItvKvicwwMjP50lHZiGHxr2QW8XXLdW+QqM1TiQCNoNNXwY zsX+01Sn67Y5/yfjEP+EbnStGhNkIrS0KAkuuBz79SfXfpUxcwaRremz2MS2l7b zgiaNWHfv7H+VUpo9+yatCzuQHynMd8Zoqurr/S0i1AXQ8eCReR0BUsMjK747ZrtwZfZHz/AJLirBk0+wF45+jHUOH74tZhrmwkP7GT7Q/hb3/nQd/ouoiYRrZzmQnAXkPWvTmo6/p+oWMy24hntZFAee5bkiU4z33LDI6DvQmLiKCxT/TIua8BDGWRg3Q9FzsB710HnADYcFavb2hOq6hcWnMnMLdct/8A0CcdqjLixvdHvhcRypHcqdplXlSQZ+0PTcb/APejPVba51O9a8j1CRGZvPHIWBJz8J9PT86Q4p1HQ9OsJIJJPF u3GViRc8pxgYB6fM0CAD/Ur+z1WfUVZhMzZnjbbf0I9PQ0b2XH+nXMMKyxTQSMP2jYyq/j3+dBHNHqcK+D+zvI18qeoHb3HpS9pY3VswnbT4Z2+7z4IPrym mAcR6nfavKltocBkZztOUJz68i/a+ZwKMOGvo3SJ/rutSNNKxHlL5J+bD/4rgUJ8BcdWGhXbQatHcwmdhz+Oox7YYdvbpV12d7BfWsdzZTRy 27/AAujZB9v8UgO4La3tIlhtxHHHH5QiLyqPanAKpytjJxjrsK4IP lLHJ7Edv8Ar0rArFSTkAdCds/2oGKCRj1bFY3JOjRyoGQjB5hsa5VWO52wOoO1ROp69bWgaO1/bS9z1UUbAFeOOCNPuoGuYiisRyq/21PtvuPaqV1nSNR0C4xdoZrQgEXCphauXVNUBcT6jcL0JAJ7Ds BVc8acVx3Ec9lbQGRV5eb4WjGR3YHr7VTQh59EknLxOyR7pLbv zEdMbYNegbGMx2yA9SMmqK+gLR5prq81Fx+wUeDH7nYtj9Pzq2 uMOL9P4Sgtnv4bqZ7lykUVsgZjjck5IAAqBhHWVBcK8V6XxTav Npkjh4ziWCZeWSM+4yfzBrKYHkLwwVZgcKPXvXAxnY12EJIDMB np6CufIBtnOepoA2QysP0PrVg8O6oTAsM5GcDlJoBicjqMp39q nbBg0QRJAxjO5WubkxuNnqeKy+uRr7LHtw0rgIQI/tMegFd3Ws2GmjFmBcXA6yN8Kn2oWstRuDbtbtIeU+neu/BDdd815/tR9J6qe30av9UuL6QyTysx7Z7VFzSiNS0rBVHc1xqmp2toGii/azegOw/Goy1m+t3Ki4bMhIxtsB7CujHx5T3I8/l+SxYV649sndBt9T1W8D6baO0Ue7TOeVU9yT0okuLuw091lnmf WbtCudiIIt98DqxFQGo8QXVxpNtYnEcUeEMcShFJG3McdffrXU DNLAoLh3SUxrIO64/XH9a7owjBHzubPkzyuTtkxql1fXV5LcQshhuXVlkXlKAdCOXts f0p5pLi1ilV2BVXHIOXGdtzjtvUJFAlurPIQoG7Y2x8/SlLQ6jq0yxaSj8rjKyFeq+qr6fxHasZ5+/QmMPsdcTanMto0drciGd9kRQGd/Yf3oa0zh363fRLqbsruwJjUhm9fMe1Wtw1wFaW/wDudSla4lPxDmzn/k3f5LgfOiTUeH7K65ZYYIo7mNeVGVcAqOx9q8leaw48qxSd/b+EW8d7RRfG+gjRrmDVdOysRbzj7rdvwPSjLQLu11vSoLtUjLF Qsi4Bww61J63piXlncWN2hHOpUg9VPrVSadqOo8IaxJEw5kDcs sTfC652I9K96MlJWmYMszUeHNPv4irxCMnoV/t0od0+94g+jfUBcWBa50qQ/tIWyYz/AFU+9FujavaaxZi5spOZOjKfiQ+hFPZI0miaGRFdHGCGGxrSrE GHCnFWl8UWAuNLm5pFGJrdtniPuPT3qTu72C1jEly/Ko+AN1PyHf5mqE1PhzUOHL4a1wlcSxOhLGJDnA64919qldB48T XOZdTcxakAQyno+Pu5/lUoLLB1HW5rrKQZjgbqoOWb5mhTU9ctbK3aVpo44h5TO26lvuo Ort7Db3qA1XiOe7upNO0mBZbhSA8bgNEB3LuD+gplcRLauL3VL j63fAeQlQFiHoi9FHvVWB1d3t5q0hiPi2VlKPMWI+sXA/i+4v8ACMdqFOJHhkubfS9NiVI4iFWNftO36k1J3GolIJ7tupGA P61n0WaU2ucYx3M4LR2p+sPt9rOE/Xf8KgEX99HuhR6Dw/bWiqMxoAzfeY7sfzzUpr+hWeuW6RXQIeMlo5V+JD+NP7SPwbZE 9BS1AwS4R4Jh4b1C8vVu3nkulCleUKqgHOfnWUWVlAHiaTCoMb k9TSeQetLOTyYO9IhSxwBvSQhextJr66S2t15pHOAKNLLSEtY1 iuJMmJTllGyk9yOpoHgnltpllhdo5EOVZTgg07utWvLtiZZWJL ZIHQn1rPJFy0ehxORiwJylG5BPbSL4/kJbBx0wa61aSV7eKOJyqyPytjYkY6VFWWrQiMxXmY3GP2nLltq IeHtPfV7ae+csY1ceApPQDrkVzw4797O7keQi+PUXtgrf6RNpk yM4JhfdHI+L+H50yuzyyrIrDl7D0q4/9Hg1LTXtbmPKsM5HVT2Iqp9c0q70q/e0vN2G6vjaRfvCuw8GyR0yeK/BEzcpQDmBGeb0xUrBJLI/g6dEWfZS3QLn1bt8hUNwpbWlzqNvbzyyR+M/hsxfEYydie+Ku7Q+GYbNFHgCNV+Elfz5R/Xv71wczk48O5s2xq+gW0DguTUJlm1aXmK+ZUK9/wCFegPu2/sKsbT9NtrGPkiiUKSC3cvjuxO5NLwwxwLiNcHG59aWUBnKhhkb 4NfLczyGTM2lqJ0KKR0gJX5V0SqLzO4UVrxFIIiwxHU+lYBkgu QzdRt0rymnPsY11LTY7+MNssy7K3r86rni7hWLV4zHMngXceQj 8v6H1FWiZUXZ2AK7k9h+NDevajbXfKlsuXU48X+3tX0XgeVyFL 9Fq4ff0Y5Yx7KBA1fhLWGZMxyp8Q+zIv8AarR4V4ns9ftyFPhX aD9pCTuPceopPX0tVgkn1HlmsvDKzoy+bl9VPXI9KrriTSV4eu 7a80nUg8M48S3aOTzgDHXHavrUzmLkk5zMhVvKuQw+9QZxhwlH qDNd6aFiuwclegf+x96zhrjQajBHDqY8CdjyrNy4jmPz6A0Ubn r/AN6piKz0viC50ZX0vU7YQ7k+IFwQfVvX50lql2ZGQvIGZzsAc/jmj/W9BtNZtylyg5x8D9Cvyqu9V0LUNAk88RuLPJIbGw/+p96TAQvk8WONZWKwL8WOrH0FXB9C+lImlpdJAI/rEjSD/gpwN++Tk1WnCPDsnF+tx2UF2kUXLzS85AeNR2A7n3FemNG0q10 fT7eys0CxQxqi/IDFQUPug27dKGuHNa1TUNTu4L/T5LWOPJXmHQZwBnue9EpGRWuX3pgdVlZWUAeKuXNbMLKcp1rcb ZIp0p2z3pCIqQkuSRg05t2FtEZ2AMh2jU9vU0pcxo4LE4f+dNW 5iw5tgoo0FnJcs2c79ye9WL9EuoBprvTpGyCA6Z+WD/Sq6JDHC1KcLagdM121uFO3PyP7g7f2ph8F12zGCdgT0OKZ8WcP QcQaaVzyXEfmhl+6fT5Gu1uVllLAghsGpW0lwwDbgim0JaKFli lsruW2uVMc0Tcjqeqn+1XH9GPGf1uOPQ9XkHjoOW2mJ/eD7p9/T8qY8fcJjVbY39koF5CMgY/er935+hqrLWd4ZdmZGQ7Y2KMD/MVw83hw5WJwkaQm4np2/uorVuRpRz8ueVSA3+OtcQJcSsrysYo1+FQDn0/H8R+FDH0d8RWuvRPHeKq6tGAzHr4oAxzj0OMA/Ki67njs4DJMyRxpu0jHAX8a+Oy43hn+hX5HZaasXOEB5sADsBT O+1OCzH7Rsv2RfiP9qEtQ42SWcwaZlkz/AOYbY/8A6jt86Z/WAo5ndmLnbOWZj6epNetwPDOf55v8MZ5UuiVvdRnu9nJSM7iNe n41BavrEWnWk05IZUwHbYqhP4779hTPVdYMU62UUD3V9JslhA3 m+cjD4R/CN/enuk8FAXI1jibwHuzhktoo8RQ49vtGvpseKOOPrFaOdu9sHJLT VOJ45XRfB02V8JczQ4mkUfdGdh17VCjhdbe4/wB/K0kMR5YoQ2/LnufnvVmavfIE8G2TlXGPL1NBOp3oilOSJJMZJJ8qfOtCbNzLA LMxyxp4IXlWLGAflSOhcVLpVylhqc3iWbthJCcvB7Me4/UVAXN+88jBCQWOTIdvyHYVDXeJJQQSQNiT3osVnoCKBJI1eOVZ I3HMrLuGHY121nBKhSQBgRgqe4qo+CuLptDcWV2Wewds9MmEnu Pb1FW3DNFNGkkciujjIKnYiri7AD9W4LW0uRf6DcyWVzF5osdF b2Pp7Uf/AEccenWv/wANroW21yEbqdhOB9pff2qPHn26j9aHNf0Nb3kmt3NvewtzwXC HDKw6b0pxGmXmDW6rT6PvpBa9nXQuI18DVU8qSfZnHr7GrJQ5z 7VmUbNZW6ygDxNDJ2p4jdc1GKSCCKewSKy4J3oExWTem8iZ2py Bnr07V0Iw1AiMZCvbauVJVgR1Bp/JDluVhtSAtiHIPw9iaBh/pGsH6rZzludAOWT29qNrO4WSNWTeqSsb+ayWWEeaNyOdT/MUfcLa2o5YJn5lYeVjT7JZZNtMJF5WFV39I3CRRn1jTouu9zEg/wDePf1o1tZRy5U99qlEZLiI8wJJBBHrSaGmUbY3slnerd6TJLG IWBSYdmx0qX1niTU+IJEa/uCyKPLCg5UB9l9fenfHXCjaFdRXdusp0a5kDyohx4Tnrv2B/So6xks4Hiigjk1G6uFPhw2cgkfm9DjOKylhxykptbRfsx7YKIm Rr2eK2jIyDK2AAAd/06fKprTYNS4jPJoIks7DHJJqkq4dx3EK9VHv+JqS4f4Aubv6vd cYz+P4RLRWCYEaZOfMQBk57fhR26rAixQRhEAwqqMVqvolkPoe gaZw1bmOxiHjN+8mbd5P+Td/l2ptqt4SCzyBUzjJp5qV5HbKVHK8v3Adh86A9e1Z3Zv/AFpN8ADIX8Kska6/q6RRlVJRf4T5mP8AQUG3c0s37SZuSPPlTqT7/wCTS+oTDl8SdvEmfcDPw1H+eZiXY0AJTTNJ5BlUHQDtWki9RUh aWLTMqqMk9MUTWPDlsiZmyzY39qKJSAz9nG4kEeVxuD3NGXBWq Xelab9ZmR5tGMrKeXLNb9MsB93PUD596iOJrGO2GY8BQOlWx9H OiR2/CelpPECZYzI6t35jnf8ACpba6NFs7+swJbC6RlaFk5w6HZh61D vqP1iFZ4Yj4XMysWzzZBqX1PhR9Clmax8STSLjJNoN/AY9eT0HtUDZ6XdWcjxW8waIvznmkC8w7hlPQ/Klkcn0XD1XZPcM6Jpeva1FJdJ/uLLlmjxsW/x0q0k3yfegfgjSp49QfVHACmIxggbNvnajmLZKCTdZXMh5cGtU AeJc1tMruvWtFSp9qUQj/vSEOraTxQRnzDtTiPfrtTIIA3Mp39qcq3TPaiwHDR5XYeY70gQ c4Iz60vE/NSkkQ5RvvTAY3EaqnjL8QGMVmmTSRcgclULYR/RhSjDYhhkHY01uwUHKo8o6H09qQFo8La4Jk+rTPmRdvnRdb3GG 5xVI6TePlWRuWeIZ2+0v96sjhzXEvYAkhCyCrRLLIjgt9Q09YL mJJYJEAdGGQR6VzovDOjaE7PpenwwO5wzqN8fM1xoUgazjGc4y P1qZJA5fdhWdFJjZyF5iTgDqTUVqV6PDJifw0Gxkb+lN7y//ANzIpyVUtt2qB1vUI4YzJcOruBso+EewHetEiWyN1i/aVHW3wsa9XY9fnQNqmpsjeDaKDlfM+d8+/tUjq+qNcRFI/LF3I2zQrO6luVRhSc49fnRYUcxoXcs7cz9z7U8tosn0Xv703Rs Lud89aWMuxVdsiqSEEGjXVpDI4YYIGA3pRDdMYU5lIMeNiKArd GmKxjOTsad3093ZxGHnYxjcKTQNCl+W1bVILGMZe4lWED/kcV6IsIEhSGFAORAEXHoBgV5x4KuM8aaZJL8KyO3m9QjY/WvRthMrpG4xjrgdqzb2Ugi5AQAQD8xTefTrO5/f20Um+fMuacqQygjuK6oGJrGscYSNQqgYAAwBXa7AVh6VsdKAE bhsAVlJXRYuFUZwKygDx/qFoocTWx/ZP+QpERMgPix86+oHSl7R8WgLHmjLEMO4962ZWJ5GkOD0NDfyT Q3jhjc/srkI/ZJBj9aTm8aHBYAmpVrKOSyeU9Qp3I67bVB+Mwj5Obb0pJ2MeW9 xzH0PepASIVHc1Brl5PKN6dQzEHHcUxkm0e2O1INF1zgr6U4gk WQde3SlXTtRWiXRCtHJbSrNADsc/L/FTVldugS9tTgZ86/dam7QkE4G1dWIFvcF8Hkk8rp2I/vQhlwcDa9HfWgBYc6sQfyFHF1KI0Rgf/UUfrXnzT72TR7rxbZy0DH8qtF+JPrlgMdedCCPnTERmraiIru5 HNgh3/maCeINVDSZuGHN2iB7fxHtS+t6hIbycRk8/iNgjqd6EL2TkcmTzysenv71QhSa+bzGXGegWmzucqx2yKau2T5 2LN3pdvNbRuPsjeoG7FY2ZvhBJraXKhwHU0jBJyZNalYE56E96 roQW6HDGy+JtntUle2Md3CUOzdiPWhHRtU+qssb5Kfyozs7iO4 iVlJOelO7GB0kU+mapBOQRLDIG9nHf9KurhHX1kT6vM2R9hqAt U06O+gZWXzYyKhNJ1S44fvVinBMJPrUSQ0ep7J+a2QmlqieF7y O90S2uInDq6DcfrUtQMzNZnat1qgCPuppobpj4fiREAAKcEH+1 ZW7gcznr17GsoA//9k=[/img]
Procedure
  1. Step 1: Prepare for Test. You should have a fully charged battery before starting – voltage would be around 12.6V for a good one. ...
  2. Step 2: Disconnect the Battery. ...
  3. Step 3: Connect the Multimeter. ...
  4. Step 4: Give the Car Time to Sleep. ...
  5. Step 5: Reading the Meter.
go on google and learn how to do a parasidic draw test, its easy
Old 02-22-2023, 09:43 AM
mollusc's Avatar
Well, that's ugly.
Old 02-22-2023, 09:46 AM
greisinb's Avatar
Bring it to any auto parts store (if you can get there) and they can run a battery and alternator diagnostic for you. But based on your description it certainly seems like an alternator problem. I have found that rebuilt alternators have a pretty high failure rate so I wouldn't be surprised if that was the issue.
Richard Gallant (02-22-2023)
Old 02-22-2023, 09:49 AM
easy to determine with the parasidic draw test, take amp draw, if its drawing amps disconect altenator if draw goes away its alternator, how is a parts store going to check your alternator ??????
Old 02-22-2023, 09:57 AM
@redwhitekat Auto parts stores do a load test on the alternator and check both output voltage and amps. But his description sounds like a voltage drop while running - once the A/C is engaged makes it way worse.
Old 02-22-2023, 10:16 AM
sqlbullet's Avatar
For those wondering...The giant block of swearing above is actually an image that is base-64 encoded: Here is the picture if you decode it:
Old 02-22-2023, 11:44 AM
really ? well around here its hard to find a parts guy that actually gets up out of their chair to check something, let alone come out to your car lol
Old 02-22-2023, 11:52 AM
@redwhitekat yea same here - pretty have to go to small good shop for that - but parts stores used to do it in BC.
Quick Reply: Discovery2 - Need help with sudden battery drain
