Diso II '99 Chirping when accelerating in gear
Being that it is a rover, it is not a very difficult job to do. It does take time though and make sure you keep track of what you take off. I have never done it on a Discovery but I have done it on cars and it was not too difficult. They machine the heads so that it makes a good seal with the new gaskets. I would suggest getting a shop manual for your vehicle before you proceed. The disc version is usually cheap on ebay. Hopefully this link will take you there http://cgi.ebay.com/ebaymotors/LAND-...58697960QQrdZ1
on
Your chirp is not from a head gasket. The biggest problem with DII's when it comes to chirping noises would be the u-joints in the double cardon section of your front drive shat where it connects to the T/case. Rover sent these trucks out without grease fittings and those two u-joints turn to powder and fail, usually taking out the tranny aqt the same time.
That being said, don't wait around, have some shop look at it ASAP. It can be rebuilt, just make sure you use greasiable joints. ot buy a kit from Bill @ www.greatbasinrovers.com/
The one other possible noise can be caused by one of the pulleys or the tensioner, they has plastic pulleys and are prone to failing, they also chirp.
Don't worry about your head gaskets, they do fail but they won't chirp at you first.
Good luck.
Mike
Good luck.
Mike
on
ORIGINAL: Dutchman Dok
What about just being the A/C fan? Mine has a chirp when I accelerate, but when I shut the A/C off it stops.
Mike
if the chirp gets higher is increase in throttle. spray the belt with belt dressing. if that is not the problem, take the belt off, restart the motor after it cools. if the sound is gone then the problem is in one of the pulleys. my first guess is the tensioner. I had a similar problem and tighten the tensioner bolt and the problem was fixed. the problem was cause by take the belt off when it was replaced I didn't tighten the mounting bolt on the pulley. With belt off it should help in the trouble shooting. hope it helps. gotta love a rover. duboff
