Do 33 inch tires require new axles?
I'm looking at getting 275/70/18's or 265/75/18s for my Discovery and I'm wondering if that will require new axles and brake lines. What about a 275/65/18 or 265/70/18?
Im planning on the 2" terra lift. I would also like to know if the 32ish tires can fit on the stock disco so I could go ahead and get the tires, but only if I have to replace the axles on the 33ish tires b/c I dont want to do that.
Thanks for your help.
you can probably run 33's on the street and be ok but I can almost guarantee if you do any serious off-roading you will explode the rear diff cross pin..and then the front cross pin trying to get it out of the woods with fwd only.
russdouble, I have a friend that broke a dana35 axle on pavement. It was a Jeep wrangler on 37's.
Adding a locker like an ARB would def make the driveline stronger as the diffs as already mentioned are the common "weak point".
The difference between those is so negligible that it wont really matter. You can tall and skinny and still be fine since the actual stress may not be as much a shorter wider tire. I have seen guys break HD axles on an obstacle and then someone with large tires and stock axles can walk right through it. So much is how you drive and how much you love the skinny pedal.
