do the recalls expire?
i have a leaky gas tank, there is a recall for the issue i have, will they still do the work?
95disco 75k miles |
RE: do the recalls expire?
If your serial number is on the list of recalled units, yes, just call and set up an appointment.
cool, ill just get it to run right before i drop it in there so i don't get the long sad list
Not to steal the thread, but if a truck was fixed under a recall and it breaks again, is it eligible for the recall again? I had my tank replaced and it is jiggling around again and there is a hairline crack by the fuel pump and vent. I get a P1496 every once in a while, but it goes away after a few starts....
How do you say"NOPE"??
Once a truck has had the new tank installed you are out of luck unless you can show that the recall wasn't installed correctly. You can easily tighten the top strap to stop the tank for giggling around. As for the leak, might want to talk to an auto parets store about a epoxy that works on fuel tanks. |
yeah, I just haven't had the time to mess with it yet. I check the code when it comes on. but it it cold and i dont havea garage. Have to do it at work soon...
ORIGINAL: okdiscoguy yeah, I just haven't had the time to mess with it yet. I check the code when it comes on. but it it cold and i dont have a garage. Have to do it at work soon... |
Got our 02 from a used lot, is there a way to look up or will a dealership know if Recall repairs have been completed on your vehicle. I tried searching the NHSTA (or whatever the letters are) and couldn't find anything that jumped out and told me that you could search by your VIN or anything.
My mom always said that if it didn't jump out and slap you, you would never find it. |
ORIGINAL: Disco Mike ORIGINAL: okdiscoguy yeah, I just haven't had the time to mess with it yet. I check the code when it comes on. but it it cold and i dont have a garage. Have to do it at work soon... |
