Does the Disco 2 have factory lockers??
Old 10-09-2014, 09:50 PM
cobbcj7's Avatar
Question Does the Disco 2 have factory lockers??
This may be dumb question, but needs clarifying..
I was under the impression that this 04 Disco is equipped with factory lockers on it.. after getting into a truck discussion with a friend I then began to wonder what exactly is in those "pumkins"? I assume it is equipped with lockers, because if not, why is there an option to pull the transfer case shifter to the left side?? Since its full time 4x4 and the High and Low options are on the right side, I just sought for some clarification on it.
I googled it, and I got no results other than people asking for advise on adding lockers to their rigs. So then I wondered more about this.
So, are there lockers on it, and are they good enough to not need an upgrade??
Old 10-09-2014, 09:53 PM
ls1morethanyou's Avatar
its not a locker its a Center Differential Lock, which basically splits the power 50/50 front and back.
you can add lockers to the front and the back so that you can have with the cdl engaged 25/25 front and 25/25 rear.
Old 10-09-2014, 10:08 PM
cobbcj7's Avatar
So is that good enough if i never plan to do severe rock crawling or mudding?? I plan to go to Uwharrie Nat'l forest and ride their trails, but I don't see myself hitting the extreme trails..
Old 10-09-2014, 11:13 PM
yeah, went to hidden falls and we had a stock disco-MetalMarine- out there having a blast.
as long as you dont have three amigos on, you will be alright
Old 10-10-2014, 08:40 AM
ZGPhoto's Avatar
Rock crawling? No, you'll break a diff soon enough. Mudding you should be fine unless you suddenly catch traction...
Old 10-10-2014, 08:55 AM
dusty1's Avatar
Just got a new work truck with the g80 auto lockers....I like them. Played with it a bit....Smooth.
Smoother than tt in disco, anyway.
Alex_M
09-23-2014 07:43 PM
lazerbrains
LR2
09-20-2012 07:31 AM
tjhappel
02-20-2011 07:54 PM
andrewmcoffin
04-11-2008 07:33 PM
Quick Reply: Does the Disco 2 have factory lockers??
