downhill descent
Old Feb 1, 2011 | 08:15 AM
iownme's Avatar
Default downhill descent
can anyone advise on when and how to use this function on an 00 D2?
i'm not an offroader, but live in upstate NY where we get decent amounts of snow in winter
Old Feb 1, 2011 | 08:24 AM
Bundu's Avatar
Banned
When you are going down a steep incline. It is only used off road at slow speeds, not on public roads at normal driving speed.
Old Feb 1, 2011 | 08:57 AM
iownme's Avatar
what if i was on a steep hill (regular road) covered in snow driving slow (10mph ish)
still no need for using t?
Old Feb 1, 2011 | 09:00 AM
Bundu's Avatar
Banned
I suppose you can use it. Check the manual on how to use it.
Old Feb 1, 2011 | 09:02 AM
Camdisco24's Avatar
Yes, only very steep hills where you may be tempted to use the brake otherwise.
To activate feature, make sure you're in low gear, simply push the button and select first gear. Let off the gas slowly and let it work its magic. Dont push the brake,even though you'll be tempted too. If you use the brakes, it overrides the the HDC and you could start sliding.
Old Feb 1, 2011 | 09:04 AM
Camdisco24's Avatar
That's a perfect time to use it. If you are in a situation where pushing the break could cause sliding and you're on a downslope, its fine. Just never on dry pavement.
Old Feb 1, 2011 | 09:11 AM
iownme's Avatar
when you say "low gear" do you mean 4x4low? or just like 1st gear.
i'm a pu#$Y on snowy hills and probably use the brake when i shouldn't.
i'm happy to crawl down a hill, in my ole truck i would put it in 4x4 low and 1st gear
Old Feb 1, 2011 | 09:13 AM
iownme's Avatar
"Check the manual on how to use it."
i prefer advice from actual users rather than a few lines from corporate headquarters :+)
Old Feb 1, 2011 | 09:20 AM
lipadj46's Avatar
he means putting the transfer case in Low and putting the transmission in 1st. 2 different shifters.
Old Feb 1, 2011 | 09:46 AM
iownme's Avatar
thanks for the info
