DownStream O2
DownStream O2
I have an 03 disco with Bosch engine, and I searched hard to find the answer before posting this.
I am pulling p0141/61 codes.
I am seeing fluctuating voltage on both banks, from .075 - .870. with resting voltage at .045
What is odd is the signal is maxing then mining very quickly. I pinned out all connections and have very little resistance in the harness. Sensors are aftermarket cheapo, but new.
Is this indicative of Cat failure or should I open my wallet and get OE sensors?
graph of down stream voltage
NTK sensors work well. Is there a known good sensor you could try? Bad cats usually cause bad smells of rotten eggs. There could also be a loss of power. If you don't have those issues, I'd try new sensors. Some will say BOSCH sensors have a lot of failures out of the box. Walker or NTK seems to work best. I ruined a sensor on the trail and replaced both with NTK, so far no issues
Those are heater circuit codes. Your sensors are functioning normally. There are four wires on the sensor, two are for the sensor, two are for the heater. Look at the Rave wiring diagram, you should have 12 v across the heater wires at the plug. Check the sensors, the heater is just a big resistor, you should have around 10 ohm across the heater wires on the sensor. The heater increases the life of the sensor and helps lower emissions during start up.
