Driiveshaft Question
I have a proshaft driveshaft and was servicing it, but noticed the nipple for the constant velocity unit hidden. I have attached a photo and will try to get a better on, but can anyone give me insight on what I am seeing? To me it appears that the outer ring has shifted. I would appreciate a more knowledgabel person's opinion.
It's not the nipple on the U Joint, but the constant velocity unit in between them. If you look past the U Joint on the left you can see in between the two U Joints there appears to be a hidden grease joint.
is it like the 2nd picture https://www.google.com/search?q=inte...read.php%25253
good information here also http://www.pirate4x4.com/tech/billav...ft/index3.html
good information here also Pirate4x4.Com - Extreme Four Wheel Drive
The original LR OE cardan (Hookes) joints don't have grease nipples for the UJ's or centre bearing. To access the centre bearing inverted grease nipple on an aftermarket shaft in most if not all cases you need to unbolt the flange and manipulate the joint to expose the grease nipple if you are lucky enough to have one.
