Drive Cycle and code clearing
Hey gang,
I have a question about Drive Cycles and clearing codes.
Took the truck out the last two nights to do a full cycle test.
A, B, & C2.
Upon completing C2, my SES light came on and I got P0134 and P0135. Odd, considering I replaced all 4 sensors, and replaced one bad sensor that was in B1S1.
I have to get this car smogged tomorrow, which I am sure it will fail since my reader shows 3 incomplete system checks and I have these error codes.
I am going to do Cycle E tomorrow morning now that I have a new tank of gas, just to go through all of the tests.
Question I have, if I do clear the codes, I am assuming I am also clearing the drive cycles. Can anyone confirm?
Also for reference the drive cycles I performed are below, which I have to do a 1AM here in LA since there is no where I can do 35mph for 5 minutes straight.
Drive cycle A
1 Switch on the ignition for 30 seconds .
2 Ensure engine coolant temperature is less than 60°C (140°F) .
3 Start the engine and allow to idle for 2 minutes .
4 Connect TestBook and check for fault codes.Drive Cycles
TestBook drive cycles are as follows:
Drive cycle B
1 Switch ignition on for 30 seconds .
4 Perform 2 light accelerations, i.e. 0 to 35 mph (0 to 60 km/h) with light pedal pressure.
5 Perform 2 medium i.e. 0 to 45 mph (0 to 70 km/h) with moderate pedal pressure.
6 Perform 2 hard accelerations i.e. 0 to 55 mph (0 to 90 km/h) with heavy pedal pressure.
7 Allow engine to idle for 2 minutes .
8 Connect TestBook and with the engine still running check for fault codes.
Drive Cycles
The following are the TestBook drive cycles
Drive cycle C1 (vehicles without advanced evaps):
The following areas have an associated readiness test which must be flagged as complete, before a problem resolution can be verified:
Drive cycle E
1 Ensure fuel tank is full.
2 Carry out drive cycle A.
3 Switch off ignition.
4 Leave vehicle undisturbed for 20 minutes .
5 Switch on ignition.
6 Connect TestBook and check for fault codes.
A, B, & C2.
Drive cycle A
Drive cycle B
Drive Cycles
- Switch ignition ON for 30 seconds .
- Ensure engine coolant temperature is less than 60°C (140°F) .
- Start the engine and allow to idle for for 2 minutes .
- Perform 2 light accelerations (0 to 35 mph (0 to 60 km/h) with light pedal pressure).
- Perform 2 medium accelerations (0 to 45 mph (0 to 70 km/h) with moderate pedal pressure).
- Perform 2 hard accelerations (0 to 55 mph (0 to 90 km/h) with heavy pedal pressure).
- Cruise at 60 mph (100 km/h) for 5 minutes .
- Cruise at 50 mph (80 km/h ) for 5 minutes .
- Allow engine to idle for 2 minutes .
- Connect TestBook and check for fault codes.
- Cruise at 50 mph (80 km/h) for 5 minutes .
- Cruise at 35 mph (60 km/h) for 5 minutes .
- catalytic converter fault;
- Evaporative loss system fault;
- H02 sensor fault;
- H02 sensor heater faulL
Drive cycle E
