Drive Shaft Grease
Old Feb 5, 2011 | 01:42 PM
hunter's Avatar
Default Drive Shaft Grease
RAVE says to use the following for general greasing. Is it what to use on the u-joints?
Multipurpose Lithium Base Grease N.L.G.I. consistency No. 2.
Thanks,
Dave
Old Feb 5, 2011 | 02:06 PM
antichrist's Avatar
Yeah, NLGI #2 works fine for u-joints.
Everyone has their own preference for what brand/type. I use Castrol Pyroplex Blue:
http://www.castrol.com/castrol/secti...tentId=7022499
Old Feb 5, 2011 | 02:17 PM
I use Green Grease.
http://www.tractorsupply.com/vehicle...-ounce-8010059
Old Feb 5, 2011 | 03:28 PM
hilltoppersx's Avatar
+1 i use green grease as well
Old Feb 5, 2011 | 04:54 PM
hunter's Avatar
Thanks, guys. Appreciate the feedback.
Old Feb 5, 2011 | 04:57 PM
And grease your u-joints 2 times a year and the slip shaft on each drive shaft once a year.
Have you already had your front drive shaft joints replaced to prevent failing?
Old Feb 5, 2011 | 05:13 PM
hunter's Avatar
Thanks, Mike. Yes, I have had them replaced. I only put about 8-10K a year on the vehicle, but change the oil every few months, regardless of mileage. I want to get into the habit of lubricating the u-joints myself, as well as this summer when I am in the eastern Sierra and Nevada.
Thanks,
Dave
Old Feb 5, 2011 | 10:12 PM
antichrist's Avatar
The service interval for u-joints under normal use is every 5,000 miles or 3 months.
Old Feb 5, 2011 | 10:40 PM
hunter's Avatar
Yes, that sounds about right. I just had the shafts rebuilt and want to start doing the service myself. I run synthetic oil, so may let it go a little longer than 3 months between changes, but want to be diligent about the u-joints.
Old Dec 19, 2023 | 11:46 AM
WoldD2's Avatar
How should I go about putting on the grease? Take off the front right wheel? Or just climb under and rub it on.
