Drive Shaft Reccomendationss
Old 11-17-2013 | 03:02 PM
xxdoylexx's Avatar
Default Drive Shaft Reccomendationss
Listen this is for all those people who ignore the draft shaft warnings on this forum. If your Discover is making a loud squealing sound or chirping sound (angry sparrows) while it is moving and stressing a little. Stop the Discovery crawl underneath check your drive shaft. Specifically the front drive shaft and on the front drive shaft check the double u joint (double cardon) toward the rear, or going into the transfer case. If it the joint seems loose, you need to fix or have it right away.
So Thursday, while driving to bring my daughter home for the weekend, from college, I decided to take the Discovery II out and air the old girl out. It is 65 miles each way and she like running a little, get ride of the carbon.
My youngest daughter uses this Discovery to go to and from school and I get to play with her on the weekends. So on the trip I started to notice a nasty squeal or chirping while the Disco was moving and under load. My Spidy sense said I think that is the frigging drive shaft. I finished my trip and parked her. Today, I decided to drop the shaft and check it out.
I dropped the shaft and my impact wrench on my head (a lot of blood) and put her on the bench. Yep she was messed up, the double cardon joint a really bad u joint I pulled it and I'm not happy with yolk where the spider cap sits on the old bad joint.
None the less I've decided after tearing down the old drive shaft that I need to bite the bullet and buy a new drive front drive shaft. Of coarse yesterday, I did a brake job on my wife's car and then bought her new tires to make sure she is ready for winter. So as always I want spend my money wisely and not get "shafted" by the price
Thus, whose should I buy? Or should I take the old OEM one and have a drive shaft shop rebuild it.
My choices are
Britsh Parts from Utah -
NEW Heavy Duty Front Driveshaft Propeller (Generation II) for Land Rover Discovery Series on Sale $350.00
Ebay - Price $250.00
Land Rover Front Drive Shaft Driveshaft Discovery 2 II 99 04 TVB000110 New | eBay
Drive Shop Rebuild - $300.00
Last edited by xxdoylexx; 11-18-2013 at 11:58 AM. Reason: I can't spell worth crap
Old 11-17-2013 | 03:12 PM
xxdoylexx's Avatar
Take a look at how bad the ends of this U Joint are. It is amazing the dang that didn't have a complete failure on me.
119,000 miles I've had it for 2,000, new water pump, new serpentine belt, New brakes, New tires, New MAF, New Fluids, Cleaned Fuel System, New Plugs, New Brake Fluid, New Shuttle Valves, New Power Steering Fluid. I love this thing it runs great. Well Until I get the drive shaft done it doesn't run at all.
Old 11-17-2013 | 04:09 PM
bballjames's Avatar
I have the BPUtah one and like it. Been on almost a year and no problems. No vibrAtion at all. It's a quality drive shaft.
Lots of people though rebuild theirs for much less. If you have a lift/larger tires I would get the BPUtah one. If just stock, I would rebuild.
Old 11-17-2013 | 04:22 PM
acg's Avatar
acg
Ditto for the BP Utah heavy-duty shaft. I had mine installed six months ago and it has been working well.
Old 11-17-2013 | 05:43 PM
jeffh's Avatar
Coil Sprung Driveshafts
Bill and his crew have been building shafts for decades. IMHO by far the best available.
I have been running the Heavy duty for close to 2 years with out a hitch.
Old 11-17-2013 | 06:23 PM
Chrisinhouston's Avatar
Consider yourself very lucky as you could be shopping for a new transmission by now.
Jimmy james (05-02-2023)
Old 11-17-2013 | 07:51 PM
xxdoylexx's Avatar
thank you for the recommendations.
I love how every needs to state you got lucky, heck I am happy I caught it, sad I have to spend money to replace it. dizzy from splitting open my forehead with my impact wrench taking the SOB off.
But the Bears beat the Ravens, so all in all not a bad day
Old 11-17-2013 | 07:52 PM
xxdoylexx's Avatar
ChrisInHouston your new name Discochris,
just kidding brother
Old 11-17-2013 | 08:40 PM
Old 11-18-2013 | 10:19 AM
drowssap's Avatar
the one on ebay I "believe" is lucky8llc. ebay store
Quick Reply: Drive Shaft Reccomendationss
