Driver's side window unresponsive
Looks like 80K miles must be the perfect storm range for these rigs... it also just threw the first Check Engine light I've seen on it - comes up as codes 1171 & 1174, but I need to research those more.
So my driver's side window is now unresponsive. Wondered if anyone had a suggestion to save me a lot of time before I just start digging in?
It worked perfect up until this; no slowness, noises, or anything that would indicate the motor was burning out. When I depress the switch, I believe I can hear a slight "click" sound, but can't hear anything from the door or window area.
I already tried a second switch since I have some spares after buying a set with heated seat switches to swap in (that was a beautiful "mod", thanks for telling me about that on here.)
Thanks for any advice on where to look first.
Sounds like the motor is out. Lucky8 has a special on now for regulators and or motors. I just replaced my son's driver side motor. Same thing, just heard a clicking sound inside the cabin, but nothing on the window. Not a hard job, really. The regulator has two parts, the motor bolted to the regulator(held on by 3 bolts) and the regulator itself. Once you have the door panel removed, you will unbolt the regulator from the door and the 2 bolts that attach the regulator to the window. Best to have an extra hand available to hold the window up while removing the regulator from inside the door.
I just did the front two doors. Both were broken plastic wheels that the regulator slides on. After watching the video it was a piece of cake. Just noticed that the rear driver window does zilch, so maybe time for a motor. Haven't had a motor die yet.
One thing that threw me was I ordered two regulators, one for the left and one for the right. I opened the boxes and they were the same. I was about to freak out thinking they sent me two passenger sides, then I simply rotated the actuator arms and suddenly it reversed. so, they may be the same part that can be used on either side.
Good pictures if you scroll down this thread https://landroverforums.com/forum/di...-repair-34345/
Watch this
Watch this
I got the door off. and noticed right away one of the bolts for the motor was just hanging there. after I removed them two of the holes were not lined up so I'm guessing my regulator it a twisted mess. I bought a used motor on ebay. I tested the motor off the battery and it did nothing. Is it safe to say the new motor to me is dead?
Instead of testing with battery now that you have door cover off why don't you just plug in the pigtail without installing motor & test it that way, & not sure about switches at that side just remove door cover from another working door & connect new motor to pigtail & test it,
