Drivetrain Wiening
I have a 1996 disco1. I have noticed that lately the drivetrain has been wiening everytime i put on the gas. I have noticed a little oil around the transfercase but dont know how to refill it. Could that be the problem or could it be something else. Thanks
RE: Drivetrain Wiening
Change all of your driveline fluids over to synthetic. There is a fill plug you can stick a 1/2" rachet into on your front and rear diffs, and on the back side of the transfer case. T-case is a little difficult to get to and you have to use a lube pump to get the oil in.
My bet is that if you transfer case is low, you have water in your rearend. |
Do not drive the truck again till you add gear oil, or you will be buyting a new t/case.
