Driving Style.
Driving Style.
Most of the time when I'm off to work its bumper to bumper, so the recommended gear is third gear (my disco is automatic). Can I shift it to "D" when I'm picking up speed? also when going downhill can I shift to neutral and coast? with the notion that I'm saving on fuel? or is that what they call lugging your engine -which sounds bad. Thanks
RE: Driving Style.
When in heavy traffic under 45mph driving in 3rd will save you gas and save the transmission from shifting to much.
Yes you can shift to drive while moving, at any speed.
No do not shift to neutral while going down hill, that is a saftey issue, if you were in netrual and all of a sudden you needed power you wouldnt have it, like in a emergancy manuvor.
RE: Driving Style.
To be honest, unless you're going pretty steeply downhill for more than a few miles you really won't notice a difference in your gas mileage. If for example your route to work has a 2 mile steep hill and you drive down it every day in neutral you might bump from like 15 to 15.3 mpg over the course of a tank.
RE: Driving Style.
cars with automatic transmissions are never supposed to be moved over any distance in neutral... your not even supposed to tow them unless the non driven wheels are not in contact with the road (front wheels up on front wheel drive, rears up on rear wheel drive, land rover on a trailer...) if it has a standard transmission then its ok...
________
BestOfBest4U live
________
BestOfBest4U live
RE: Driving Style.
Other than driving in 3rd in slow traffic, the best thing you can do to save gas is watch your driving style. Go the speed limit, dont punch the gas, and dont over brake. Little things like that will save you gas over time. Actually, its proven that 55 is the optimal speed to go (something with aero stuff, blah blah, science, blah blah...) but I still thinkgoing the speed limit is the best bet to save gas. But hey, with gas being at $1.84 here im just happy it doesnt cost a small fortune to fill up everytime!
RE: Driving Style.
ORIGINAL: discoxd
HOWEVER, if the engine is running and the trans is in neutral then youcan tow it as far as you want since the engine will be turning the transmisison fluid pump and the trans fluid will be pumped through the transmisison cooler and the transmission will not overheat.
WARWAGON
10-02-2012 12:03 PM
Street Wolf
09-27-2008 08:58 AM
