Dropped a 10mm nut down intake manifold...
The title says it all, mid-way into my new spark plug wire job, plenum removed and all, a little 10mm nut slipped out of my hand and tinkered down into the abyss. Its headed somewhere in the direction of cylinder 8 (back left when you are looking from the front of the engine). I have tried retrieving it with a little magnet from both down the intake, and through the spark plug hole with no avail. My magnet on a string gets stuck on something before reaching the bottom and cant get all the way down. Does anyone have any idea where it could have ended up? Needless to say, Ill be covering the intake with a rag from here on out.
It has to be at a top of one of the valves. Maybe you could coax into the combustion chamber and out the spark plug hole by slowly rotating the crank by hand. Considering the price of a Valley Pan Gasket, I would just take off the lower manifold, and not risk damaging a valve.
I recommend using some Permatex Aviation Gasket sealant on the gasket when you reinstall. Also, the Genuine lower manifold bolts come with some blue thread lock on them. I trust you have the RAVE Manual for the bolt and torqueing sequence. You’ll want that on right. Take your time, clean the bolt holes well.
Howmang miles Les on your injectors? Maybe new washers for them?
