dropped sleeve?
Can anyone tell me how to know if you have a sleeve that has dropped? I have the head off and im looking at the cylinder in questionand it looks perfect. Im sure I need to do some type of measurement but I dont know what to look for. Im working on a 96 disco 4.0 with a 140k. I did a compression test an a leak down test on this cylinder and the comp was 90psi(the others were 145/150)and I had 80% leakage in the cylinder and I could hear the pressure coming thru the valve covers, I couldnt hear anything thru the exhuast or the plentum. Thanks
over hearting, water in oil, in my case the sleeves looked perfect, intil the mechanic took the engine apart then found the sleeve problem. I went ahead a replaced the block, since my sleeve was cracked.
I liked the truck so much, I did it this way.
Ralph
Ralph
Yea looks like thats what im going to have to do as well. I have all the symptons except I dont have water in the oil or vise/versa, but it does run hot and I have low compression in two cylinders. Thanks
If you don't have water/coolant in your oil I doubt you have a dropped sleeve. Bad head gasket, warped heads or a bent valve maybe but not a dropped sleeve. Before you rip your engine up get the heads machined and a valve job. I had a bent exhaust valve that resultantly produced low compression. I really, really doubt its a sleeve. Have you severely overheated the engine? If not, I'm puttin my money on the aforementioned, not a dropped sleeve.
Thanks you guys, I have the heads at the shop getting resurfased as we speak. I have had all the valves out and they all seemed to move freely and seat ok. Im not sure if it was really overheated bad or not. It needed head gaskets when i bought it. The previous owner assured me it wasnt overheated but who knows. The mech at the shop saw a spot on one of my heads where he thought pressure would escape so hopefully resurfasing will do the trick. Thanks again.
Im not sure yet Ill know tomorrow, He's working on them today an tomorrow.I know the spot were the head gasket blew ate away the aluminumhead a little bit an He did say from just looking at them and feeling that spot that that could definately be the reason for compression loss in that cylinder. That was the major reason for the resurfasing. Imnot sure yet if there was any warpage.
Thanks
Thanks
