Eliminated ACE Pump
So I had been having problems with the power steering pump changed that then had problems with the ACE pump. Looked for the ACE pump and I found it nowhere. So I called the dealer and they told me I could eliminate it which I did and replaced the serpentine belt with a shorter one. Now the only problem is that the power steering is still very hard. I checked the power steering reservoir an the fluid doesn't gurgle. What am I missing?
Mike, not to hijack, but my PS pump is making noise, and my ace pump under the passenger door pillar "kicks on" every 12 seconds. This thread makes them sound related? I would love to get it working right, cause that noise is driving me nuts, and I want to make sure it is working. I have tried to search, but it keep dropping the term ACE as too short. Can you give me a hand?
01 Disco 2 SE7, 120K
ACE site:https://landroverforums.com
I was thinking about buying the serp. belt for a non ACE motor also because my pump is surging every ten seconds on the dot. I put a screw driver to it to make sure that was the sound and you bet it was. So instead of buying a new/used one I thought I would just bypass it and didn't think it would hurt anything if it was not running it shouldn't make a difference it would be just like it it didn't have it... Right? Anyone know anything different?
