Engine issues, rough idle, bad o2's..
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Heck you can buy the OEM sensors (in a bosch aftermarket box) from amazon for less than that. I just bought a pair, and they have the land rover part number etched into the sensors, and the connectors are the correct colors, etc.
you can try heat but that connection has already been heated and cooled a million times just buy the converter exhaust.
I would soak it in SeaFoam Deep Keep and put i big *** box wrench on it or make a full commitment and cut the wires off and use a socket and breaker bar.
Also just because you bought the 02 sensors from Atlantic British does not meen they will work. There are a few old post from people who went thru two or three sets of AB 02sensors before getting there money back, there is a reason they are only 69.00.
I did buy the rear o2's from Amazon.
I also used the 02 from antlic British . And the guy the works on my disco said for what ever reason these 02 do not work right . So I took his advice and changed them out to oem 02 sensors to find a perfect smooth idle . He says he has tried them several times from Ab and talk to them and they do not no why they cause a bad idle . His thoughts are they are a standard 02 . Thery are even a different shape and style
After 80 miles of driving today here are the codes that have popped up again. I cleared the codes this morning.
Pending Trouble Codes:
P0300 Random/Multiple Cylinder Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
Trouble Codes:
P1300 Boost Calibration Fault
P0305Cylinder 5 Misfire Detected
I find it interesting the computer thinks the 303 and 305 are both "pending" but also "hard" faults.
Still waiting on plug wires... I also am smelling a sweet smell of anti freeze, however when I smell my exhaust it doesn't smell sweet nor did it fail the head gasket block tester. Really wish the wires would get here sooner rather than later.
Trouble Codes:
Did you check the female ends of the 02 connectors? I had some similar codes, and after messing around for weeks with new 02 sensors, I found one of the female connectors was slightly fouled, one of the four prongs was blackened. Cut and spliced a new one in, boom, fixed like 3-4 codes.
I've heard some speculation that the reason that the left front o2 sensor fails (and is more difficult to remove) is that coolant from the throttle body heater leaking gets on that sensor. Not 100% on this, but you might look and see if it's leaking.
I could see how that would make it fail. It was leaking and I just replaced the gasket, all is good with the throttle body now.
I had to get a tap to clean up the threads on the y-pipe because half of the ones from the sensor were still in the bung.
