Engine oil leak
Old May 29, 2020 | 11:56 AM
merebel's Avatar
Default Engine oil leak
Ok so I still have a front area oil leak. Passenger side it is on and the oil filter had oil dripping from it not a lot but a drip. New front oil seal and oil pump and gaskets. Oil when parked drips from oil filter end and from the steering rods and from front diff bottom as it settles down. Looks dry behind the harmonic balancer now :-). Video here has passenger side
Can't get the .mov to upload will try to ficure it out and report it
Old May 29, 2020 | 12:43 PM
Sixpack577's Avatar
Front of intake manifold to block??
Old May 29, 2020 | 01:30 PM
merebel's Avatar
Old May 29, 2020 | 01:31 PM
merebel's Avatar
good possibility
side of block is clean and dry were the valve cover is also
Old May 29, 2020 | 02:25 PM
Sixpack577's Avatar
Originally Posted by merebel
good possibility
If it's not the timing cover or valve cover, and it's above the oil pan, then the intake manifold is all that is left, and that's a common leak point.
Fortunately, it's not hard or expensive to fix either.
Old May 29, 2020 | 02:29 PM
merebel's Avatar
good and I should do plugs and wires at the same time too
Old May 29, 2020 | 02:59 PM
Sixpack577's Avatar
Yeah, might as well while you have easy access to the coils.
Good time to do injectors too if you haven't already, as reman sets are cheap on ebay, around $60 for all 8.
You should also get the o-ring for the coolant pipe on the passenger front of the lower intake.
The front, center coolant neck can stay on the lower intake.
You'll have to pull the valve covers too, but, if the gaskets look ok, I'de clean and reuse them, and I put a small bead of silicone on both sides of them anyway.
Also easy to knock out the factory oil seperator with the valve cover off to do the Best4x4 pcv valve mod(if you haven't already).
Old May 29, 2020 | 03:02 PM
merebel's Avatar
good ideas most expensive part will be plug wires hahahaha
Old May 29, 2020 | 03:03 PM
Sixpack577's Avatar
Yep...too easy to spend money on these things...
Old May 29, 2020 | 03:05 PM
merebel's Avatar
Yup I still have to patch the rear frame first
replace 3 bad door lock actuators
which I have all the stuff to do here now lol
