Engine Temp question
I would first like to start off by saying thank you to all the great experienced ppl here, I have read a ton of the threads on this topic and more, I have to say that there is a lot of good advice and input on the DII and how to keep it running and happy .
As I mentioned, I have been reading the threads on engine temp... as I have a 'long in the tooth' DII with 152,000 mi and want to ensure I get a lot more life out of her... I have done all the maint suggested by Atlantic British (as I just purchased her). I then bought the Ultra Gauge to start monitoring the engine - my temps are:
What I am wondering is, should I be diagnosing anything OR is this normal for an experienced DII Thank you for the help...
Cheers!!
- idle at a lights: 200 - 205 F
- Highway: 196 F
- climbing the mountains in Colorado Springs(30 mph): 200 - 209 F
Cheers!!
It appears from your temps that you are fine. However this is what I have done. I know that the longevity of the head gaskets is related to high temps at least in part and I wanted to put off the dreaded head gasket job as long as possible. My water pump began to leak so I replaced the water pump, worn hoses, thermostat, throttle body heater, radiator, and viscous fan clutch. I used the 180 degree thermostat and now only use the green antifreeze. I found a lot of sludge from the Dex everywhere I looked. I have a lot more confidence that the Rover will stay within normal operating temps now. Even so, I am pretty obsessive about checking coolant levels. Good luck.
