Entire Dash Cluster not working
Old Mar 3, 2009 | 01:56 PM
tomfraser's Avatar
Default Entire Dash Cluster not working
My speedometer, odometer, gas guage, trip miles, tachometer, engine temp, diff lock light, and other lights do not work
my turn signal does, and my high beams does
the connections are all good at the cluster, not sure where they go though
any ideas?
Old Mar 3, 2009 | 02:00 PM
tornado_735's Avatar
any ideas?
Check the fuses. If the dash is electronic (IDK if it is) then a fuse could cause that. Had it happen to my parents car.
Old Mar 3, 2009 | 02:02 PM
tomfraser's Avatar
you know what I think about fuses
going to check now
Old Mar 3, 2009 | 02:06 PM
tomfraser's Avatar
all fuses good
Old Mar 3, 2009 | 02:13 PM
Knowing those rascally british electricians, you might want to check you right rear marker light. It might have burned out and took your dash with it lol!
Old Mar 3, 2009 | 02:19 PM
tomfraser's Avatar
lol
if anyone has any ideas please post as I have to go soon
Old Mar 3, 2009 | 02:56 PM
tomfraser's Avatar
going through the rave manual those things are not all on one harness, so i'm kinda nervous about this
Old Mar 3, 2009 | 03:01 PM
Rover Chris's Avatar
are the gauges not working or the illumination on the gauges? I would check the ground in the kick, that's where they should be grounded.
Old Mar 3, 2009 | 03:43 PM
Looking at a cracked circuit board, I bet.
Old Mar 3, 2009 | 04:49 PM
tomfraser's Avatar
Alright... got the multimeter and tested pin 7 on connector c207, no 12v
checked for 12v at fuse 14, got it
so somewhere in between i have a problem, I think i'm just gonna run a new wire so I don't have to disassemble the dash though
