-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Entire Dash Cluster not working (https://landroverforums.com/forum/discovery-ii-18/entire-dash-cluster-not-working-20295/)
tomfraser Mar 3, 2009 01:56 PM
My speedometer, odometer, gas guage, trip miles, tachometer, engine temp, diff lock light, and other lights do not work
my turn signal does, and my high beams does
the connections are all good at the cluster, not sure where they go though
any ideas?
tornado_735 Mar 3, 2009 02:00 PM
any ideas?
Check the fuses. If the dash is electronic (IDK if it is) then a fuse could cause that. Had it happen to my parents car.
tomfraser Mar 3, 2009 02:02 PM
you know what I think about fuses ;)
going to check now
tomfraser Mar 3, 2009 02:06 PM
all fuses good
tornado_735 Mar 3, 2009 02:13 PM
Knowing those rascally british electricians, you might want to check you right rear marker light. It might have burned out and took your dash with it ;) lol!
tomfraser Mar 3, 2009 02:19 PM
lol
if anyone has any ideas please post as I have to go soon
tomfraser Mar 3, 2009 02:56 PM
going through the rave manual those things are not all on one harness, so i'm kinda nervous about this
Rover Chris Mar 3, 2009 03:01 PM
are the gauges not working or the illumination on the gauges? I would check the ground in the kick, that's where they should be grounded.
Disco Mike Mar 3, 2009 03:43 PM
Looking at a cracked circuit board, I bet.
tomfraser Mar 3, 2009 04:49 PM
Alright... got the multimeter and tested pin 7 on connector c207, no 12v
checked for 12v at fuse 14, got it
so somewhere in between i have a problem, I think i'm just gonna run a new wire so I don't have to disassemble the dash though
