Exhaust manifold crack or gasket leak or...
Hey all.
This has all of the makings of a manifold crack or leak, but I thought I'd ask anyway, to see if anyone has a different opinion or experience.
I started to notice the noise over the past couple of weeks, it's especially pronounced when I'm accelerating at anything more than 1/3 throttle.
So, what say you, LRF commentariat?
- H.
- H.
Another less painful approach is to hook up the outlet side of a shop vac to the exhaust then look for leaks using a spray bottle filled with soapy water. With the exhaust cold you won't have to smell your burning flesh plus it will probably leak more than it does when it is hot and expanded.
Racer X (06-12-2015)
I've been slowly collecting the parts needed to look into this, as I don't have a place to let the truck sit for days on end should the problem be a cracked manifold. I should have a replacement manifold in another few days along with all the gaskets, etc. I'll pull the manifold, and if it's just a gasket I'll sell the spare on eBay. If it's a crack, then I've got a spare ready to go in!
I'll post up with the results when I make the repairs.
I had a similar sound. I let the truck cool overnight, started it and stuck my hand down there to see if I could feel anything. This only takes a few seconds, you don't have to worry about burning your hand.
Sure enough I felt air coming out between the head and the block at the # 6 cylinder. I hope this isn't your issue but with the motor cool you will have no problem finding your issue.
