Expansion Tank Replacement
Yes I know, another coolant leak thread. But this is a Land Rover forum, so what do you expect?
Just found out that my coolant expansion tank is leaking on my D2. I don't think that the hoses attached to it are the issue because there isn't any orange crud around the ends of them. I am pretty sure that the reservoir is the problem because its underside of it is always wet with coolant. I also see coolant drips on the shock tower.
I think my only option is to replace the tank with this one: Overflow Tank : Overflow Tank Assembly
My question is this: Will the stock cap fit the non-oem unit? I just bought this cap 10k miles ago and I don't want to buy a new one if I don't have to.
Thanks.
Thanks.
Thanks.
Thanks.
Well the first crack I saw was in the middle of bottom of the tank (at a seam between the compartments). I found another one though.
I just got home from work (the disco is not my daily) and saw a puddle under the car (about a 2ft diameter). I saw that the tank was nearly empty and the throttle body return line had snapped at the tank. So in short, my disco is non-op for a while.
So it looks like I need a tank, tank cap, and a return line.
Looks expensive...
Thanks for all your help guys.
Looks expensive...
