Explain Connector C0505 from Rave
If anyone replaced front right ABS Sensor with a long wire type I would like to make sure before I cut those wires.
Page #103 and page # 444 from Electrical Library says; "From Front RH ABS sensor pins C0517-1/2 to SLABS ECU pins C0505-4/5 on G wires" Just wanted to confirm I need to cut wire # 4 and 5, right? Is there any better way to connect this wires in case I have to take this off down the road. Thanks for your help in advance |
2 Attachment(s)
IMHO your work would be simpler if you used connection point C0517. See attached photos from connection pages of the electrical library of the RAVE.
Savannah Buzz, thank you. I agree with you that does not seem too easy.
I have tried that with a new one that plugs into 517 and repaired my old one that was torn where the original problem started. Still getting 044:Front Right sensor output low 064:Front Right sensor electric fail talked to Storey he thinks there is ground issue. I don't understand where the ground would be, this is not touching anything. So my logic tells me I need to make sure to eliminate the wire possibility. If that does not solve the problem then I may have to look to replace the Hub. I have eliminated the Shuttle valve issue. This is frustrating and starting to question the Land Rover's engineering competencies. LOL Any suggestions would be appreciated. |
