Extended brake lines
Old Mar 16, 2014 | 06:08 PM
BayerischeDisco's Avatar
Default Extended brake lines
So I lifted my truck with terrafirma's 2in lift. Also bought 2in extended brake lines but to me it didn't really look like I needed them so I didn't install them. Can someone educate me on whether or not I should install them or return them. Thanks in advance.
Old Mar 17, 2014 | 07:25 AM
ralphobell's Avatar
You don't have to install them. But you are at their max now. However if you do a lot of off roading and plan on trying to get more articulation in the future, you will want them.
Old Mar 17, 2014 | 01:35 PM
Dane!'s Avatar
If you plan to disconnect the sways id say put them on... Theyll give you a little firmer pedal.
Old Mar 17, 2014 | 01:45 PM
dusty1's Avatar
even if you are not benefiting from the extra length, you would be upgrading from the worn squishy rubber ones. imo, any improvement in braking is worth it.
Old Mar 17, 2014 | 02:21 PM
jeffh's Avatar
what Dusty said. Your current black rubber brake lines are old, worn out, and just tired. Replace them with the new SS extended ones you have and be done with it. While your there, might as well do a whole system flush with fresh fluid.
Old Mar 17, 2014 | 07:31 PM
Thanks gents I appreciate the insight. I will go ahead and put them on.
Old Apr 30, 2014 | 02:39 PM
overover02's Avatar
@BayerischeDisco... I'm assuming you installed the Extended brake lines, but even if not... did you purchase the kit with 4 or 6 lines? I see them being sold both ways. I'm in the same boat as I'm getting ready to install a 2" lift and although I know the Extended brake lines are not required, thought for the same reasons as dusty1 & jeffh mentioned that I'd get them installed and while there do a complete flush/fill. I guess I'm just trying to find out what most people do/recommend when replacing the brake lines; the 4 line kit or the 6 line kit?
Old Apr 30, 2014 | 02:48 PM
ZGPhoto's Avatar
overover- I've got a +2" set from Goodridge I'm taking off to go +6" custom lines, 4 line kit. Would do $55 shipped if you're interested.
Old Apr 30, 2014 | 02:57 PM
drowssap's Avatar
+6" no more street?
Old Apr 30, 2014 | 03:06 PM
ZGPhoto's Avatar
Originally Posted by drowssap
+6" no more street?
+6" lines, +6" shocks, 4" lift. Still street-worthy
