Extended Rear Ladder?
There is a metal lip over the top and bottom of the door. They bolt to the ladder assembly and keep it in tension top to bottom. It was a very simple installation although I did strip the bolts that came with it and went to the hardware store and replaced them with grade 8 bolts and nuts.
Toran (04-11-2016)
Seems like the picture on the left can hold more weight but still attached to the rear door anyway. I have the one on the right but never had problems with it. Ladders are great to hold on to when you climb the rear bumper especially when you raise your truck. But most of the time I use the rear tire to climb the roof rack. Easier to get things from the roof.
The one on the right has versions too with one using a larger round tubing and the other with solid square rod. The best addition to those upgrades are having a rear step that comes with the SE7 discos. It makes a lot easier to climb the bumper to the ladder no danger ripping your pants.
Toran (04-12-2016)
Please post if and when you hear anything from BajaRack. I bought my full-length ladder at the same time I bought my rack which was shortly after they became available. I really like the ladder and can't imagine why they don't still offer it. I have since had to replace my roof rack so I have the newer mounting system now. The replacement was not the fault of BajaRack. I had taken my DII to a shop for some work and they ran it through the wash. The kid who drove it through the wash didn't realize it wouldn't fit and mangled the old rack trying to get it out of the wash. I wonder what happened to the car wash equipment? I wonder if that guy still works there?
