Exterior A pillar
I am trying to get this exterior A pillar on and it is killing me! I tried tonight and cannot get it on? The plastic clips are all good on the part. I did not get new metal clips could this be a factor? Please help! I am going crazy!
Phil |
From my understanding the trick to putting this back on is to place the clips on the trim first and then line up the clips to the truck frame. Starting from the bottom, slap the plastic trim thus pushing the metal clip on to the frame of the truck.
We have the center cowl replacement coming up and will be doing this shortly. 2003 Discovery 130K with high miles complete. |
They are a bit tricky to install or remove. To install them, I loosen the clips a little where they fit to the body and put a dot of silicon on the clip. As previously mentioned, install the clips on the part first and then install it on the vehicle. You have to give them an open hand slap right where the clip is. Hard enough to seat the clip, but not too hard or you will break it. Patience is the key.
Originally Posted by borchera
(Post 344233)
We have the center cowl replacement coming up and will be doing this shortly. 2003 Discovery 130K with high miles complete. The A pillars do not need to come off to remove the windshield cowl just a heads up.:eek: |
Originally Posted by lr2001silver
(Post 344295)
I have not started the project and if I can avoid the A Pillar step I would be most appreciative. 2003 Discovery 130K with high miles service complete. |
This will sound pretty silly: but how do you install the plastic rivets? I have some from NAPA, but not working as I thought to make them stay in.:eek:
Here is a short writeup with pics that I did for installing the A Pillar.
https://landroverforums.com/forum/di...uctions-58027/ |
