Fan clutch bolt removal
I told ya those OEM Allen bolts were a PITA.. I just used a ratchet with a the correct allen head socket vs using an actual small allen wrench (much more torque with a ratchet). If that still won't work due to stripped allen heads sometimes torx bits actually will bite better, or just get out the vise grips. If none of that works then drill the heads off and call it a day. The USA made Fan Clutch uses different thread bolts so you don't need to save the OEM allen bolts anyways.
Just saw new fan came with bolts. Will go to work on the old ones. Thanks.
