Favorite Brakes?
Old 06-29-2021, 08:42 AM
robert.juric's Avatar
Default Favorite Brakes?
So my front brakes are starting to make a bit of a grinding noise. I reckon its time to replace them anyway since I haven't touched them since buying my D2. I've always had an issue with brake dust, I assumed that was due to cheap pads. Does anyone have any experience or recommendations for quality pads/rotors?
Old 06-29-2021, 03:38 PM
PalmettoDisco's Avatar
If you're getting a grinding noise, make sure your pads aren't completely worn out and now have metal on metal, scoring the rotor.
That's the biggest concern, if you hear grinding. Generally, the brakes will chirp if pads are getting too low on braking material.
Old 06-29-2021, 05:16 PM
No chirping or squealing. It is grinding on braking at lower speeds. Gotta order something.
Old 06-29-2021, 05:41 PM
Dave03S's Avatar
Akebono ceramic pads leave no dust and last FOR EVER...
You might want to think about taking one side apart to see what is really going on before you throw money at it though... Could be a pebble caught in the works, or even binding caliper pins.
The following 2 users liked this post by Dave03S:
JUKE179r (06-29-2021), PalmettoDisco (06-30-2021)
Old 06-29-2021, 06:08 PM
I may do that, but I’ve been wanting to replace the pads just because the dust for a while now.
Old 06-29-2021, 06:16 PM
My brake order just arrived today
power stop rotors
akebono pads
will let you know how they are
Old 06-29-2021, 11:15 PM
JUKE179r's Avatar
+1 for Akebono
Old 06-30-2021, 09:28 AM
Also agree on the ceramic pads for longevity and low dust. Be careful after install, get a feel for the ceramics before having to do a panic stop.
robert.juric (06-30-2021)
Old 07-01-2021, 09:40 AM
I checked today, the pads to appear to be pretty low so they do need to be replaced. I'm just not sure how to check the rotors. They felt smooth without cuts or anything, but I don't know how to tell how much is left on them.
Old 07-01-2021, 10:06 AM
tnrangerover's Avatar
I had a bunch of grinding after I bought my D2 8 months ago. I bought the following from Roverguy for a good deal. this is all four corners
> rotors (TOP OF THE LINE/BEEN SELLING FOR 15 YEARS) 200
> guide pins and rubber boots for them. INCLUDED IN CALIPER PRICING
> +2” stainless lines 70
> pads 120.00 OEM JURID (LAND ROVER SUPPLIER)
> calipers (but not caliper holders) 350.00 all 4
> locator screws 4
It was a noticeable difference and felt good to just renew everything from the rubber hoses down.
At the very least, grease up your guide pins when you remove the calipers. I've got 4K miles on this setup so far and it works great. The fronts are a bit dusty though. but I also only wash the rover once every 2 months pretty much.
Quick Reply: Favorite Brakes?
