Fixing my trail scar,.. from the city.
so lets just say somebody (MY GIRLFRIEND) can't drive. Going to attempt some body work, which I have never done and don't know how it will go. here is the damage. let me know if anyone has any tips or good tools to use. i wanted to try and use one of those little make a hole and pull the dent out kits. i found the paint match online here http://www.automotivetouchup.com/cho...odel=Discovery
Slow down there......you don't go right to a slide hammer.
You need to strip the interior around the area and see how much can be hammer & dollied back out. This is not something you get right on your first try, and not something you first try on something you are trying to fix - you really should be finding some old body panels to learn on.
Since it appears that you have creases in there, you won't be getting it all the way out. If you're really careful and practice well, you can get it pretty close to flat, sand it with some 80 grit, and put a few very light coats of boy filler (NO - NOT BONDO - that stuff is garbage. Try something decent like Rage Gold). Sand it smooth and then you are ready for a high build primer and more sanding.
When you're done with that, I can guarantee you that you will not be able to prpperly paint it. Forget the paint code you got: that's not what color your truck is anymore. That's what color it was when it was new.
How much time and money you want to spend depends entirely on how good you want it to turn out, but without having done more than a little bit of this stuff about 10 years ago, I was able to turn this:
into this:
Note - I replaced the door and re-sprayed the entire car (obviously). And the fender isn't actually entirely bolted back on the car in this picture, which is why the lines are off.
So it's possible. But I did a lot of practice work to make it happen.
No way I would have tried blending the paint myself, even it it was a single stage paint.
into this:
I agree that you need to come at it from the inside, remove all the interior trim, its easy, and hammer it back out.
Or, here is a novel idea...call your insurance company and see what they say, if you dont like what they say then go to a body shop and get a estimate, its free.
The decide what you want to do.
Remember, the body panels are aluminum...
