FLUSH OR NOT??
RE: FLUSH OR NOT??
ORIGINAL: Switzer
It seems DII's had oil coolers until a certain VIN in 2002. It is beyond me why an engine which needs an oil cooler suddenly does not, but engineers are a dirty lot of people who don't always have a good reason for the things they do. I am fortunate enough to have the oil cooler.
Cheers,
Pete
Cheers,
Pete
That was about the time that Land Rover found that most Land Rovers never went
off road so why spend the money on a oil cooler when most people did not need it.
RE: FLUSH OR NOT??
Spike: You mention dropping the oil pan and cleaning, etc. if one were to do the flush. I would like to give it a shot on my 95 Disco I, it has 150k, 50k of which I have put on, and it has probably never been flushed. Bit of a novice here, is there much difficulty in taking the pan off, or in replacing once clean, or any general "heads ups" you would tell us to look for. Thanks
RE: FLUSH OR NOT??
I have never dropped the oil pan and a Disco but it looks pretty straight forward. You will only need to do that if you lose oil pressure after your engine flush.
I am not a fan of engine flushes, but that is just me.
If you use a full synthetic motor oil it will do that same thing as a engine flush only it takes longer. Full synthetics have more detergents than dino oil. Penzoil full syn has 46% more detergents than their dino oil for example.
If you have been using full syn for these 50,000 miles then I think that you could do the ATF flush and not have to drop the oil pan.
Personally, I would just keep using the full syn and not worry about it.
Just some light reading, I use Mobil 1 but I am always looking to educate myself.
http://www.pennzoil.com/products.html
