flywell and torque converter
Old Jan 12, 2012 | 09:50 AM
drowssap's Avatar
with the flywheel off you should be looking at the back of the block, the seal and the end of the crankshaft with an aligment dowel in it. You can remove the seal several different ways I use a couple of small sheet metal screw into the seal and then pull pull the seal out. Do you have a couple of the rave? them is a real good picture in section 12.21.20.
Old Nov 8, 2021 | 07:09 AM
Eddie discovery's Avatar
Default 00 disco 2 torque converter help
I replaced the flywheel and attached the transmission to the engine but I have to force it in now it is in place but I'm not sure if the torque converter is lined up with the pump any tips on how to check or do i have to take the engine out again please let me know thank you so much
Engnur
Aug 30, 2009 05:12 PM
LRScott
Mar 6, 2009 11:42 PM
sailorcolin
Apr 17, 2008 08:21 PM
kraelo
Apr 1, 2008 12:02 AM
jared
Dec 20, 2007 06:51 AM
