FM Bluetooth transmitter reco
Just search amazon for one, they have a hundred of them for under $15 and they all do the same thing. However I would definitely look into the GROM audio bluetooth upgrade... it works in place of the CD player and the sound quality is amazing compared to the FM transmitter, and it also has a USB and AUX cable for you to use.
Had one. It sucked.
I tapped directly into the CD under the passenger seat and added a ⅛ plug. Then it’s just a little Chinese Bluetooth unit or plug the phone in direct.
Also means that when the Bluetooth unit fails (which they seem to like to do) it’s just that that needs to be replaced.
Very cheap solution.
Fair point, depending on your priorities. My '99 has the "high-end" Harmon Kardon system and all I wanted to do was add Bluetooth without getting into the amp system or modifying the stock appearance. I agree the GROM is not inexpensive, but as I said, it depends on your objectives and priorities.
Had one. It sucked.
I found one for $7.99 in a thrift store. This model works great. I modified the wiring a bit to make it go on/off with radio power.
https://landroverforums.com/forum/di...47-99-a-93149/
Had one. It sucked.
be aware; I no longer have the stock head unit or the cd changer....but was thinking of reinstalling them so I could regain my steering controls; and still adapt BT capabilities. I have a thumbstick BT adapter now...but I would REALLY love to get rid of it and de clutter my dash.
thanks.
