Fog light question
Old 01-23-2011 | 05:26 PM
texmbr's Avatar
That's where mine are also.You sound good to go. My wife's 01 is a SE with all the goodies and after looking here fog lights are plugged in there.
Old 01-23-2011 | 06:07 PM
Disco owner's Avatar
Perfect, thanks for checking and confirming on both your Discos.
Old 01-23-2011 | 07:05 PM
sloan74's Avatar
If the bumper has the mounts your good to go. Just find/order the lights and install. I installed the passenger fog light yesterday (mine was missing when I bought the truck), it was a pretty easy job. Ordered the light off AB. You will need some small screw bolts from the hardware store that you can put a 1/4 driver on (the smallest socket driver you have). You will also need to remove the back plate there (2 small nuts) so you can get your hands up in there easier.
Old 01-23-2011 | 08:48 PM
Hey Sloan, thanks for the response. I just looked at AB and the EOM fog lights are pretty expensive.
I'm leaning towards some aftermarket lights and put them on my brush bar. I'll probably head to Walmart tomorrow and get a pair of Hella 500s for about $65.
Old 01-23-2011 | 08:51 PM
sloan74's Avatar
ahh ok yeah def go that route then. would be much cheaper.
Old 01-29-2011 | 11:20 PM
As an update, I finally made it over to Walmart today. I got a set of Hella 500 FF lights on sale for $35. Not sure if that is everywhere but thought I'd let the LRF family know.
Old 01-30-2011 | 08:40 AM
Snafu / Disco Fries's Avatar
Did that come with everything needed including the relay? Will the stock fuse and switch work OK with the Hella set up? What about wiring? I'm actually trying to track down a relay for my Hella's on the brush guard right now and looking at my options.
Old 01-30-2011 | 09:41 AM
SDinDS's Avatar
Yes, how do they look? Post a pic Any modifications needed to mount them?
Eric
Old 01-30-2011 | 10:30 AM
Yep, it came with everything. I'm hoping to tap into the pre-wiring behind the passenger side bumper cover, but we'll see.
I haven't installed them yet, but will post pics and give an update after I do.
Old 04-15-2011 | 07:33 PM
garagepro's Avatar
Default No power to my fogs
I installed a fog light kit from Atlantic British and connected to the factory harness, but they didn't light up. I called and found out there is a relay under the left kick panel that may not be installed.
Indeed my relay was missing, but after installing one - I still have no power to the fog lights. Checked the fuse and it's good with power at the fuse box.
Any suggestions?
It's a 94 DISCO
Quick Reply: Fog light question
