Fox or bilstein?
I am looking at re-doing my suspension. I am Looking at the bilstein 7100 with poly bushing (instead of heim), and the fox emulsion. It seems like a 12" front 10" rear seem to be right for 3" springs. Looking at the OME 751/763 combo. Maybe adding a 1" spacer if needed for extra clearance.
Any new opinions on the fox or bilstein option?
Best bang for the buck if had when you save up enough money and go for a good lift. And unless you are going long on the shocks, the OME Sport Shock is the best for the buck.
Bilstein makes a good shock, especially if you are going 7100 or better, for up to a 3" lift they are about 1/2" shorter then factory and their warranty is terrible compared to the 3 year from OME.
You've got that backwards: 10" up front, 12" in the rear.
I run Fox emulsions. Only issue I had was that the spherical bushings didn't last (you hear the same things about the Bilsteins), so I switched to poly (which you already mentioned). Otherwise, I love 'em.
Ok some I'm confused, I got the owner at the Rover Shop up here in Calgary telling me that OME aren't all that it's made up to be? Tells me that terra firma is the way to go. Now I'm thinking OME with 2" lift. What are those terrafirmas like? I'd like to go bilstien but not that rich right now. What about Boge? Sorry for jackin your thread.
Thanks for the correction. Did you spec your valving? Where did you order from?
Now, I don't run sway bars so the heavy valving is compensating for that. I'm running linear RTE 3" springs. The highway ride is firm and feels safe, without completely killing the offroad experience (just let more air out of the tires to soften the ride
).I got mine years ago from Downsouth Motorsports. I picked up the poly bushings some time after from ORW.
jpschreff
Jul 19, 2014 08:49 PM
