Freaking Out
Old 09-23-2009, 12:42 AM
sloppyjoe's Avatar
Originally Posted by DKH2Hrnt
I just bought my 03 Disco yesterday and I saw on here that my VIN# is in the range of the oil pump problem!!!! What should I do?!?!?!
at 108k i would just drive it like you stole it and enjoy the rig. from all the research i did before buying my 04 i was gonna buy a 03 because they were so much cheaper. but i wanted the CDL and all the 03's in my area were right in the wheelhouse for the pumps going to hell. if the CDL is not a issue for you and you enjoy the truck as is i would not sweat it and just rover on =)
Old 09-23-2009, 08:01 AM
DKH2Hrnt's Avatar
I love the truck and it is in immaculate shape, it rides very smooth and the engine sounds good, but I almost had a seizure when I saw something about the VINs and mine was in range.
Old 09-23-2009, 11:00 AM
sloppyjoe's Avatar
at 108k miles its gonna be something else to go bad before the engine does i am betting
Old 09-23-2009, 11:21 AM
okdiscoguy's Avatar
Keep an eye on out for your oil light, but if you made it this far, you will probably be ok. It doesn't mean that all are going to fail, just that it might.
Old 09-23-2009, 11:35 AM
DKH2Hrnt's Avatar
Well you are correct. As soon as I drove it off the lot the check engine light came on and I found out the #4 cyl in misfiring. No warranty but the dealer said they would pay for what the mechanic was doing to try and fix it. The mechanic put some new tubing because the old one had some holes in it, but of course the check engine light came back on when I got home. I'm hoping it's just the wires.
Old 09-23-2009, 11:40 AM
sloppyjoe's Avatar
replace the wires with magnacores and pop in some new plugs. lots of guys like the bosch +4's. i am not a fan of bosch products and i use NGK iridiums in every vehicle i own.
in any case this should solve your misfire issue
Old 09-23-2009, 11:42 AM
okdiscoguy's Avatar
Bosch +4's and Magnacor 8MM wires, not the 7MM. That should do the trick.
Old 09-23-2009, 11:46 AM
DKH2Hrnt's Avatar
The dealer said they just replaced the plugs a week ago, so I'll get the 8mm wires and hopefully that will resolve it. Where is a place to find a good price on these wires?
Old 09-23-2009, 11:48 AM
sloppyjoe's Avatar
apexperformance has the best price on 8mm magnacores
Old 09-23-2009, 11:50 AM
sloppyjoe's Avatar
also pop out a plug and see what the dealer replaced with. if it is some sort of crap autolite $1.88 spark plug i would do yourself a favor now while you will have all the plugs exposed and swap em now. my bet is they wont last 25k miles.
Quick Reply: Freaking Out
