-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Front Drive Shaft Boot (https://landroverforums.com/forum/discovery-ii-18/front-drive-shaft-boot-51176/)
jafir Jul 13, 2012 01:01 PM
The pictures you've posted show a broken gaiter. You can replace it, and grease the slip portion of the propshaft without issues.
Some people have also brought up the universal joints. This is unrelated to the question you've asked, so this might be what is confusing. They ARE important to replace on Discovery 2. It does require a press or vice or something to replace them. If by "centerize" you mean balance, you shouldn't need to balance the shaft just for a joint replacement, most of the time.
jfall Jul 13, 2012 01:06 PM
You would need to take the factory shaft off and put grease fitting on it.
Problem is you need to take it apart
due to the drill shavings getting into the existing oil.
Enrique5 Jul 13, 2012 01:08 PM
I'm looking and the boot that I'm referring to or "Gaiter Propshaft" looks to me like its for extending and retracting of the drive shaft, it is separate from the function of the U joint is it not? So are you guys warning me that I not only need to fix the boot, but check these U joints?
Enrique5 Jul 13, 2012 01:09 PM
nevermind this was answered before I finished posting LOL
Enrique5 Jul 13, 2012 01:20 PM
Ok so there is no need to balance it. And yes that is what I meant jafir. :)
As for putting the grease fittings, yes i would think you would have to take it apart. I'm sure them shavings would have a party in there every time it spins if you didn't. I do have a press and several vices and the U joint only costs $20 at Atlantic British. Sounds like it would be a good idea to put a new U joint when doing the boot. Especially since I may be doing some long travels in a couple of months.
dgi 07 Jul 13, 2012 04:41 PM
8 years and 99k on the clock. Its time to replace the u joints. They live next to a cat and get baked out every time you start your truck. Just lubing them at this point isnt gonna do much.
Enrique5 Jul 13, 2012 05:55 PM
ok so I'm replacing u joints and the gaiter. Thanks Everyone!!!
Enrique5 Aug 25, 2012 07:04 PM
I'm rebuilding the front shaft and I need to install the boot. I need to separate the 2 parts of the shaft to put the boot. Does it just pull apart? Or is there a trick to it?
FLDiscoII Aug 25, 2012 08:27 PM
It does just pull apart. Be sure to mark it first, though. There is a key spline that will keep it from fitting back together properly if it isn't lined up just right.
Disco Mike Aug 25, 2012 08:34 PM
Don't forget to replace the centering ball also or you will have a failure shortly after reinstalling.
