Front Drive Shaft Rebuild Assembly Question
After spending a couple nights gettings the all the U joints disassembled I'm getting ready to put new ones on and put the shaft back together. I have done the forum search and read most of the related posts but I still have a question. For the middle U joint I had all 4 caps off before I could remove the double cardon side from the shaft. But in Kevin Liu's write up he had the new middle U joint re-assembled onto the shaft WITH CAPS ON first before putting the double cardon side on. It seems counterintuitive. Can someone who has experience with the rebuilt shed some light on this? Thanks!
Chrisinhouston
11-09-2009 01:37 PM
cardon, disassembly, discovery, double, drive, driveshaft, freelander, front, land, rebuild, rebuilding, rebuilt, rover, shaft, shaftrebuild
