Front Driveshaft Question
I need to know if this driveshaft is the genuine non-serviceable shaft or an aftermarket shaft. I took it out of the box the other day so I could start the process or installing new u-joints when I noticed a small hole on the shaft itself. Looks like it could be a hole for a grease nipple fitting but Im not to sure. Does the genuine front driveshaft have a hole like this in the shaft itself? Based on all the information provided on this forum I always assumed there was no hole for a grease nipple to be installed thus a non-serviceable front driveshaft. Please help.
TRIARII, that shaft looks original to me from an earlier 1998-2002 D2 but with one minor exception, it appears that the single UJ has been replaced with a greaseable zerk type. Otherwise the cardan Hookes joint looks original. From memory the 2003/2004 shaft has certain differences, typically, the slider portion was on longitudinal rows of ball bearings internally and not splines.
Drive Shaft
thanks,
I would guess that it is for a grease zerk, but a few years ago, I witnessed a car on fire and noticed the firemen hosing down the underside of the car. They told me it was to cool the driveshaft as they could build up pressure with the heat from the fire and explode from the expansion of trapped air. Never found out if this was true or not but it makes a nice story..
