Front O2 Sensors: tried everything
Old 09-27-2018 | 03:02 AM
ReconDoc83's Avatar
Default Front O2 Sensors: tried everything
I’ve tried everything I know to get the front O2 sensors to release; I can’t get them to break loose. I’ve tried 3 different penetrants; had a mechanic try to break them loose...and I just have no success.
anyone have any tips or tricks to get the damned things to break free?
thanks
Doc
Old 09-27-2018 | 04:21 AM
redwhitekat's Avatar
Maybe some heat and small pipe wrench
Old 09-27-2018 | 06:30 AM
JUKE179r's Avatar
heat will definitely work
Old 09-27-2018 | 07:47 AM
Twix's Avatar
Get a bigger wrench. Use a hammer on the wrench to break the corrosion free
Old 09-27-2018 | 08:31 AM
cfairless's Avatar
I know what you mean! I replace all 4 of mine a few months back and it was a bear! I was worried about breaking those welds loose! Just keep at it and quit when it gets frustrating so you don't do something dumb! :-)
Old 09-27-2018 | 09:09 AM
DiscoBuckeye's Avatar
I ended up breaking the tip off the sensor and putting a full wrench on it. Don’t give up, you will get it
Old 09-27-2018 | 11:27 AM
2Guinness's Avatar
Heat, heat, and more heat.
Mine were a monster to get off
Old 09-27-2018 | 01:03 PM
User's Avatar
Heat and penetrant didn't work for me, cut the pipe out, took the massive impact out, got it out, which it took the threads with so did helicoil and weld back in
Old 09-27-2018 | 02:35 PM
zuke's Avatar
A new small pipe wrench. A good one with slanted teeth. Then a cheater pipe.
Old 09-27-2018 | 03:36 PM
Want to know how hard it was for me in more detail...
Quick Reply: Front O2 Sensors: tried everything
