Front Passenger floor is soaked with some liquid...
Noticed a really bad smell in my 03 Disco II the other day... I keep the thing meticulously clean, and never take foodor drinks in the car, so I immediately suspected a problem and started looking around... I found the front passenger side carpet (and the floor mat) were both soaking wet...
What the heck could this be? Is it leaking from the undercarriage or from behind the dash somewhere?
TIA for any ideas...
on
No tools necessary.
Crawl under the truck with a flash light and maybe a small piece of wire, look up at the floor board on either side of the tranny and look for two small black nipples on either side of the tranny that come thru the floor and drain down, squeeze them or use a small piece of wire to open them up.
You will get wet.
Mike
You will get wet.
Mike
Granite Disco
01-23-2009 02:18 PM
